1970 W25 aft hood is raised (fitment issue)
Old Jul 10, 2014 | 04:39 PM
Funkwagon455's Avatar
I have been struggling for some time trying to get the left aft corner of my hood to close flush with the fender when closing the hood. The hood will simply push down into place, but when shutting the hood it always tends to be elevated on the drivers aft side. I have seen other cars on the show field have this problem as well, and it makes me wonder if it is a common problem and if so what is the corrective action. My doors are fitted as near perfect as an A body gets as are the fenders. If anybody can share their situation, I would very much appreciate the insight!
Old Jul 10, 2014 | 04:54 PM
oldzzy's Avatar
wait.... what....
Mine did that to. The body guy said the bushings were shot in the hinge, so i got new hinges, and that fixed the problem.
Old Jul 10, 2014 | 06:11 PM
4speed455's Avatar
Mine does that too.
oldzzy, did you but repop hinges or original gm?
Old Jul 10, 2014 | 06:13 PM
oldzzy's Avatar
wait.... what....
I'm guessing they were repopped, cuz i got them from Fusick. You can have your originals rebuilt.
Old Jul 10, 2014 | 06:17 PM
Thank you for your reply Oldzzy, who can rebush them?
Old Jul 10, 2014 | 06:21 PM
4speed455's Avatar
Now are you using the "lightweight hood" springs or originals? I found the hood would not stay up with the lightweight ones. My hood is an all fiberglass repop from tamraz btw.
Old Jul 10, 2014 | 06:29 PM
oldzzy's Avatar
wait.... what....
I have never used this company, but someone told me about them. http://www.hoodhingerepair.com/
I am using original springs as my hood is an original hood with the steel frame. There was a thread on here recently about someones hood that wouldn't stay up, and they figured it was because the person greased the hinges.
Old Jul 10, 2014 | 06:59 PM
brddg's Avatar
Lubing the hinges won't be any reason for the hood not staying up, simply makes it easier to open and close. Use a good sprayable lithium as maintenance. Funkwagon, if your interested I have a very nice set of original hinges that I'd be willing to part with. PM me if interested.
Old Jul 10, 2014 | 07:12 PM
brddg's Avatar
Funkwagon you may also just try to lube the hinge with the lithium as I described above. If the hinge joints are binding it may result in exactly the way your hood is acting. It is always the drivers side rear that has problems first and lubing the pivot may give it just enough movement to close flush and won't cost you but a couple of bucks for the can.
Old Jul 10, 2014 | 10:07 PM
costpenn's Avatar
Heath, is it a OE hood or aftermarket?
Old Jul 10, 2014 | 11:06 PM
73aussie455's Avatar
Acceleratii maxim rapidus
My Delta88 hood has exacly the same problem as well, I've been looking for a fix. Thanks for the discussion and ideas on a fix and cause
Old Jul 11, 2014 | 03:47 AM
It is a Thornton hood, either II or III gen, but I am certain that my OE hood would do the same. The hinges have been cleaned and lubed very well, that should not be an issue but if they are just worn then it would not matter. I'll do some research on the bushing option and reply back later. Thanks for all of the help.
Old Jul 11, 2014 | 03:57 AM
My442's Avatar
SMS in New Hampshire does great work on hood hinges.
I am very happy with mine.
Old Jul 11, 2014 | 05:38 AM
oldzzy's Avatar
wait.... what....
I forgot about SMS. My buddy has had a few done for his Mopars by them, and is happy with them too.
Old Jul 11, 2014 | 06:25 AM
costpenn's Avatar
Heath, does it go down further if you remove the cowl weatherstrip? The vert I just did has a Fiberglass Concepts hood on it, and no matter what I did, it rides up in the same place. Read a thread here about those hoods being too thick in the back vs. the OE hood, so I have to leave my weatherstrip off or it looks like ***. Someday I will face up to the error of my ways and get a decent hood. I doubt the Thornton hood has the same issue, but you might want to check that if you are tired of pulling your hair out.
Old Jul 11, 2014 | 06:42 AM
No, There are no clearance issues, as mentioned it simply pushes down and stays if you palm it down. I would prefer to fix it right though. I suspect the hinges are just worn after only 44 years of use. I've sent a quote request to SMS and am waiting for a reply.
Old Jul 11, 2014 | 10:32 AM
I would like to go the SMS route but am not wanting to make the painter wait the 3 week overhaul turnaround plus shipping time. In the interest of moving forward I called Fusick and ordered new springs and the last right hinge they had. The left side is on backorder until August. My right side combined with weak springs were what was giving fits. So we will soldier on and once the car has been removed from the chassis, I'll send my old hinges out to SMS.
rcktdoc
Jan 6, 2014 10:22 AM
Freebeer
Wheels and Tires
37
Aug 15, 2012 08:58 PM
RATCHETMASTER
Jan 13, 2012 07:54 AM
charlierogers
May 1, 2011 09:49 PM
browndog9
Feb 5, 2011 02:19 PM
