1968 Cutlass moldings
Hello,
I own a 68 cutlass the driver side fender is a 68 and the passenger is a 69. I was wondering if any of the moldings for the front of the fender are different from a 68 to 69 the eyebrows I guess you'd call them. Also are there any reasonable companies that sell these moldings and also looking for the front of the 2 piece molding and looking for the mounting hardware for the moldings front to back the studs as my car is currently getting painted the factory color silver green. Also I was wondering is there away to make sure the rear window and roof doesn't rust from a vinyl top as I'm thinking of reinstalling one or would painting it be better with a gloss black or what would you recommend? Also can a 69 hood hinge work on the passenger side and a 68 hinge work on the driver side or will this cause problems? Cause currently has both 68 hinge with the passenger fender drilled for the two holes. Thanks
John
John
Last edited by 1968Cutlassfallbrook; October 30th, 2010 at 12:27 PM. Reason: wanted to add more information
69442murph
January 28th, 2015 07:36 AM
jstrits
August 21st, 2014 04:37 PM
ros6872
November 12th, 2012 10:01 AM
MIRADAMANia
August 23rd, 2008 07:39 AM
