425 ci HEAD BOLTS
425 ci HEAD BOLTS
Where is the best place to buy head bolts for my 65 olds 425 engine? Was on the hot rod power tour and car puked near memphis tn. Overheated and think blew head gasket. Rented a truck and trailer and towed back to oh. Pulled engine down and heads checked/ milled a touch and would like to put new head bolts in. It showed weak compression on cylinders 1,3, and 5.
Thanks all
bob
Thanks all
bob
Understand that the factory head bolts are not torque-to-yield and can be reused with no problems if they have not been abused. Aftermarket bolts do not have the special stud-head fasteners for accessory brackets.
Is it safe to mix ARP head bolts and factory stud head bolts? Isnt the torque reading different from one another? Lets say ARP is 90 ft lbs and the factory is 80 ft lbs. Will the head warp from different torque setting?
Bad plan! Those are old bolts.The new arp bolts will insure that you get proper head seal.Using the old bolt for bracket accessories is one thing but to totally use all old bolts is another.Most engine builders steer away from the old head bolts and opt for ARP. Call up some machine shops and ask them.Do what you want this just is trying to get you to reconsider.JMO
These, again, are not torque to yield bolts, they are 100% re-usable unless over torqued or rusted badly.
Cleaning all threads and applying lube should go w/o saying, but, now that it is said, I agree entirely.
What will ARP bolts provide for the extra money? Bragging rights. Window sticker. Peace of mind- if you are worrisome.... extra factor of ignorance.
Honestly, since the original bolts can with no doubt be re-used at the factory loading level... even if the ARP bolt is less near its yield point, the difference is between "entirely in safe zone" and "entirely in a somewhat larger safe zone". No difference in real life.
Unless you are into power levels requiring o-ringed cylinders, then we can talk about the need for enhanced fasteners.
stanzaschance
Jul 28, 2015 06:38 AM
Oldssupreme
Feb 6, 2013 12:39 AM
