69' 400 Compression Test help?
Old Jan 25, 2015 | 06:56 AM
Snolab's Avatar
So my son and I did a basic comp test on my 69 - and here is what we got:
1- 170 2- 160
3- 162 4- 170
5- 160 6- 162
7- 170 8- 122 ??
So for you more knowledgeable guys what should I take away from this? I believe the car to have about 60k miles on it. Engine blows no smoke, sounds great, starts right up etc. Is it likely #8 cylinder has a bad ring? Just looking for how I should move forward. Need to pull engine as oil pan is badly dented and leaking pretty good. Thoughts?
Old Jan 25, 2015 | 07:06 AM
Was the car warmed up?
Were all the spark plugs out?
Was the throttle wide open?
Did you do a second "wet" test on #8?
If all are "Yes," and #8 didn't change when wet, then do a leakdown test - could be a slightly burned valve, or just one iffy cylinder.
Old Jan 25, 2015 | 07:09 AM
Snolab's Avatar
Eric,
Yes to all the questions except the redo wet test. We just did not know enough to do that and ran out of time. So are the other numbers within a reasonable range for this engine?
Tom
Old Jan 25, 2015 | 07:26 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yes, those are acceptable numbers. It could be a leaky valve, which is the reason for the wet test. Inspect the spark plug on number 8, if there is oil or deposits will probably mean worn rings.
Old Jan 25, 2015 | 07:33 AM
+1.
Overall numbers look fine.
A wet test, where you squirt in some oil (I always crank it around once or twice afterward, to eject any excess oil and prevent the dreaded hydro-lock) and then recheck the compression, will read higher if the problem is ring seal, as the oil will help seal the rings, but will not change if the problem is "upper," ie: leaky (burned) valves, head gasket leak, cracked head, etc.
Old Jan 25, 2015 | 08:19 AM
Cylinders 3/5 may be pointing to a future head gasket issue, #8 may have an issue.
shamusj
Mar 4, 2016 06:48 AM
dman0712
May 12, 2011 12:43 PM
Stevec
Apr 19, 2011 03:09 AM
IB Adrian
Sep 12, 2009 12:43 PM
1973olds98
Jul 7, 2009 01:02 PM
