Suggestions: Valves for ProComp Heads
Old Aug 13, 2014 | 12:55 PM
VinMichael's Avatar
Hello everyone.
I ordered a set of bare ProComps and need some valves. What do you run, or suggest?
Old Aug 13, 2014 | 02:56 PM
Smitty275's Avatar
Engine Builder
Depends on what your building them for. Feel free to call me.
Smitty
M&J ProFormance
330-495-4582
You to realize that its not just put valves and springs on and away you go. Your going to have to cut the valve seats and probably at a minimum clean up the decks.
Old Aug 13, 2014 | 03:48 PM
VinMichael's Avatar
Smitty
M&J ProFormance
330-495-4582
Thanks. Aren't you the one with the really thin head gaskets? .016 if I remember.
I will be using it for hotrodding. So 95% street and 5% track
I won't mind doing the decks because I goofed and got Icon887's and I'd like to get 10:1. And 450 horsepower.
And I was planning to get a 3 angle valve job. The machinist told me I need to get all the parts for the heads first.
Old Aug 13, 2014 | 04:26 PM
Smitty275's Avatar
Engine Builder
Yes, I have the .011 shim gaskets. I've got what you want for valves too. Might even throw a few pointers for valve angles and prep.
Old Aug 13, 2014 | 04:43 PM
firefrost gold's Avatar
glad you put that up smitty I was thinking that a valve job should be done to the heads to match the valves and check the seats. Or is just a good Lapping all they need ?
Old Aug 13, 2014 | 07:11 PM
cutlassefi's Avatar
Like Smitty said a good multi angle valve job will do.
Check out "70cutty's" build that I did. Out of the box Procomps made 493/570. Very respectable.
Old Aug 13, 2014 | 07:53 PM
VinMichael's Avatar
Sounds good. I'll give you a call.
Hi Mark I was going to message you soon. I need some valve springs.
Checked that build out and am impressed. This was my face when I saw those numbers:
Old Aug 14, 2014 | 04:52 AM
cutlassefi's Avatar
Originally Posted by VinMichael
Hi Mark I was going to message you soon. I need some valve springs. I got you covered, have a few different ones in stock.
I thought it did well too! Actually better than I thought it might, especially on the torque.
Old Aug 14, 2014 | 06:35 AM
Smitty275's Avatar
Engine Builder
The seats need to be fully cut. As is they are just seats that gave been out in the casting. No working finish of any kind other than the 45° is about 45°.
RAMBOW
Sep 16, 2013 03:52 PM
boese1978
Aug 4, 2013 02:40 AM
boese1978
Mar 4, 2013 03:10 PM
joepenoso
Aug 4, 2012 12:58 PM
RAMBOW
Oct 6, 2011 11:49 AM
