Rusty engine parts (what to do)
Old May 15, 2008 | 03:23 PM
nonhog's Avatar
Registered car nut
I have a 455 (apart) that has surface rust on the cam and crank
new cam and turned crank . I want to remove rust(dont think there is any pitting) and continue to store them till ready to put together . should I let the machine shop check them ? I have coated cranks with axle grease in the past ?
what works for you ?
Old May 17, 2008 | 05:11 PM
71 delta88guy's Avatar
Many will say no. But...... I'de do just the same. Ditch the cam-break in is hard enough with a new cam let alone a rusty one- Dust off the crank oil it and use it later. Unless going for big power,power adder or high rpm use. besides if the cam is an old one,there are much better profiles available now.
Old May 18, 2008 | 04:22 PM
88 coupe's Avatar
Junior Member
Originally Posted by nonhog
........ surface rust on ........
Depending who is doing the defining, "Surface rust" can mean anything from a slight discoloration, to "you can't see through the part, yet".
........ should I let the machine shop check them ? ........
It would be your best choice.
Norm
Octania
Mar 23, 2015 07:51 PM
clay69
Nov 3, 2011 08:10 AM
no_grain_no_gain
Ninety-Eight
Jan 10, 2009 07:21 AM
ozzyolds
Jul 31, 2008 02:34 PM
tarheeldoc
Oct 23, 2007 11:01 AM
