74' EGR Block Off Plate Purchase
Old Jan 27, 2013 | 09:17 AM
terrapin's Avatar
While tracking down some idle issues I noticed my EGR valve assembly was cracked right through the iron on the left mounting bolt. Does anyone happen to have a block off plate I could purchase?
I'd rather block it off then spend the money on a new EGR valve
Old Jan 27, 2013 | 10:38 AM
67 Cutlass Freak's Avatar
Block off
Rocket Racing sells fuel pump block off plates that will work as EGR block off as well. If you don't want a fancy aluminum block off, I have a plain chromed steel one I could sell you for $7 including shipping. Let me know if you want a photo or some measurements. Here's a link-
http://www.rocketracingperformance.c...8euvef0qkgb8r3
Old Jan 28, 2013 | 06:48 PM
terrapin's Avatar
That would be great for 7 bucks. What is the measurement just to make sure it is the proper fit?
Old Jan 29, 2013 | 10:53 AM
Sent you an email with measurements & photo.
Old Jan 29, 2013 | 12:23 PM
jfb's Avatar
jfb
hey buddie if this does not work out make your own and cut a gasket to match,maybe you can get the metal for free somewhere also.
Old Dec 13, 2014 | 02:54 PM
Green_Goblin's Avatar
Just an FYI on these Rocket Racing fuel pump block-offs, since this thread is where I got the idea to buy one of these. They will NOT work for blocking off the EGR. The bolt holes on the block-off plate are 2.5 inches apart. The EGR bolts are three inches apart. Well, at least on my '73 Olds 350 motor.
Sean Blake
Dec 14, 2013 09:34 AM
69ishHoliday
Jul 16, 2013 04:37 PM
mmcilroy
Aug 26, 2010 08:42 AM
Chumley
Jun 24, 2009 08:40 PM
Redog
Dec 14, 2007 01:17 PM
