Hedman shorty headers
Old May 2, 2012 | 12:58 PM
LX89mustang's Avatar
Is there any reason the Hedman shorty header for the SBO would not work on the BBO ?
Old May 2, 2012 | 02:46 PM
Redog's Avatar
Deck height
Old May 2, 2012 | 05:43 PM
Originally Posted by Redog
Deck height
If the OP is talking about these, deck height is not an issue. Of course, I still question the value of shorty headers.
Old May 2, 2012 | 06:29 PM
Yes Joe , those are the ones I am speaking of . I wanted to know if they will work in an A-body . I have a set of long tubes and find them to be just a mess . The fact that you have to move the brake distribution block , cause heat issues with the starter , also grab anything on the road due to hanging so low tends to displease me to no end . I was hoping these can be used as an upgrade to manifolds on a basic street/strip motor .
Given my years of racing and building Mustangs from the past , shorties always made for a nice "middle of the road" upgrade . The HP difference on mild street motors vs long tubes always made up for its self if you ever needed to work on the car .
Old May 2, 2012 | 08:43 PM
bigD's Avatar
i'd say that the port height is probably the biggest issue. if you arent averse to doing a little port work with a die grinder they should work fine... the bolt pattern is the same as is the port spacing.
you could check and see if sandersons still offers the p/n 451 shorty for the 455...
Old May 3, 2012 | 08:39 AM
citcapp's Avatar
The header tubes on these are only 1-5/8" in diameter so they are not any better then the W/Z Manifolds made by thornton
Old May 3, 2012 | 09:38 AM
I've got $10 that says Hedman uses the same flanges on their BBO and SBO headers.
Old May 3, 2012 | 10:07 AM
GAOldsman's Avatar
"Car"mudgeon
X2 The W/Z manifolds flow pretty well. Not as restrictive as most exhaust manifolds out there.
Old May 3, 2012 | 12:39 PM
Any thoughts on these in an A-Body ?
http://noxiouscustoms.com/OldsShorties.html
http://www.noxiouscustoms.com/_wizar...eaders_web.jpg
glide65
Apr 4, 2014 06:47 AM
Magna86
Jun 23, 2013 06:55 AM
scott71
May 23, 2011 07:20 PM
nonhog
May 15, 2008 03:18 PM
nohn
Oct 26, 2007 06:21 PM
