New oil pump
Old Mar 26, 2012 | 08:31 AM
Stevec's Avatar
New oil pump
What do you guys recomend for an oil pump and pick up for a 68 olds 400 engine? What else will I need to do this job?
Old Mar 26, 2012 | 09:47 PM
ah64pilot's Avatar
Steve, I know I've seen you around but I'm not familiar with your engine...is it all stock? Is it in the car?
If it is stock I would get a normal Melling pump. You will need an oil pan gasket and oil and filter.
Old Mar 27, 2012 | 12:59 AM
Bluevista's Avatar
Registered
Make sure you weld or braze the pick-up tube to the pump. The high volume Melling pumps have a pick-up tube that bolts on, not sure if that would be right for your engine though.
If the engine is in the car you may need to pull the bolts out of the motor mounts and raise the front of the engine to get the pan off. I made a lifting jig out of some angle iron, bolted it together like a "U" then bolted it to the front of the engine and used a floor jack to lift it. A crude copy of the jig they use in the FSM to do it but it worked, you can use an engine hoist too. Jam some 2x4's between the engine and frame for safety once it's lifted.
Old Mar 27, 2012 | 02:36 AM
Stevec's Avatar
It's basically stock Im thinking of pulling the motor to clean it,swap heads ( worn guides) and timing chain/cam. It's in the car but the radiator,water pump,cyl heads are all off. At this point what's left to remove the engine? 6 bell housing bolts,3 torque converter bolts and 2 engine mount bolts?
Thanks guys....
Old Mar 27, 2012 | 11:41 AM
ah64pilot's Avatar
Thanks guys....
That's it...
Old Mar 27, 2012 | 04:50 PM
joesw31's Avatar
I would use the Melling high volume oil pump with a diesel oil pan gasket. Now, since the engine is out of the car, maybe, new rings and bearings, and a rear main seal.
Old Mar 28, 2012 | 07:48 AM
68442CONVERTCO's Avatar
Aloha, Tony
Yes.
At this point you might as well pull the motor. Harbor Freight has engine stands for around $60, sure beats lying on your back!
Old Mar 28, 2012 | 08:10 PM
64Rocket's Avatar
I suggest the Melling "M22F pump. Use the stock pick up. I put some heat to the pump pick up hole and freeze the pick up tube. Don't put to much heat, for you may warp the pump body. Just enough heat and insert the tube fast and you will be set.
I also take the cotter pin out for the pressure valve and re-drill the hole .250 over, clean it all, push the spring and retainer down and re-insert the pin in the new hole. helps with the pressure.
Gene
Redog
Oct 20, 2015 03:29 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
86pontiac
Feb 17, 2010 11:24 AM
cts-v
May 26, 2009 06:52 PM
