Broken Head Bolt
Old May 20, 2011 | 08:55 PM
vmathy's Avatar
Broken Head Bolt
I am doing some engine detailing and had my valve covers off and I noticed the head of a bolt laying next to a valve spring. After a closer look I see the head bolt on the left head at the front is broke off. I cant believe I didn't blow a head gasket! I used an easy out and removed the remainder of the bolt from the block. Now should I find a head bolt and reinstall it and go as is - or - is there a risk if one was weak maybe there is a chance that more of them will break? Would I be better to buy a complete set of head bolts and replace them all? If I do should I loosen the intake first then install and retourqe the head bolts then retourqe the intake? Is there a chance that loosening the heads to replace the bolts without replacing head gaskets will result in blowing the old gaskets?
Old May 20, 2011 | 09:10 PM
I'd say don't rock the boat.
You've got the rest of the bolt out, and you don't have a leak yet.
Get a new bolt, oil it up, torque it down most of the way, then go around and torque the whole head, as though you were just putting it on the block, just in case any others have loosened.
Don't over think this.
Old May 21, 2011 | 03:10 AM
Yellowstatue's Avatar
X 2
Old May 21, 2011 | 11:30 PM
Redog's Avatar
x3
Don't look for more work
Old May 21, 2011 | 11:45 PM
toro455's Avatar
From: Issaquah, Washington ( 15 miles east of Seattle )
I might have an extra bolt if you need one....
Old May 22, 2011 | 11:56 AM
vmathy's Avatar
I was just about to post asking if anyone had an extra or knows where I can get one. Send me a PM and see if we can work it out. I was hoping to find one in the Chicago area so I can pick it up and get this thing rolling.
Old May 22, 2011 | 12:25 PM
greenslade's Avatar
be sure to blow the hode out befor installing new bolt.
Old May 22, 2011 | 02:03 PM
I just bumped into a whole ZipLock ful of them in the barn, but I agree that someone nearby would be the best choice.
Old May 22, 2011 | 05:58 PM
toro455's Avatar
vmathy, pm sent
Old May 22, 2011 | 06:06 PM
redoldsman's Avatar
Proud Viet Nam Veteran
It is usually a good idea to run a tap in the hole and clean the threads but you will not be able to do that with the head on. Just get it as clean as possible and lightly oil the bolt so you get an accuarate torque reading. I agree with the others. don't create more work.
Old May 22, 2011 | 06:19 PM
chequenman's Avatar
You haven't said what type of engine you're working on but in most cases before you install that Head Bolt, Thread Sealer should be used because most Head Bolts go into Water Jackets and you start a coolant leak you won't be expecting.
Old May 22, 2011 | 07:19 PM
vmathy's Avatar
Sorry its a 455 with G heads.
Old May 22, 2011 | 07:22 PM
toro455's Avatar
vmathy, another pm sent...
Old May 22, 2011 | 11:02 PM
chequenman's Avatar
Exclamation
Water jacketed Head Bolt Holes. soooo get some thread sealer and torque those Head Bolts like MDchanic suggests.....
Old May 25, 2011 | 10:10 AM
vmathy's Avatar
Thanks all I got a bolt from a local machine shop he had an extra and just gave it to me - locked down and ready to button up
bills65olds
Dec 23, 2012 05:03 PM
stlbluesbrother
Jun 15, 2012 08:45 AM
louie
Mar 9, 2012 08:29 AM
dallasite21
Feb 2, 2010 06:59 PM
veltboy618
Mar 30, 2009 05:52 AM
