intake gasket vs turkey tray
Old Mar 4, 2011 | 06:45 PM
RAMBOW's Avatar
Ben
question... if you order the turket tray, does that go under the intake gasket set, or do you not use a regular intake gasket at all if you are running the turkey tray?
btw... this is for a cast iron intake.
Thanks- just trying to figure out what needs to be ordered.
Old Mar 4, 2011 | 07:06 PM
Oldsmaniac's Avatar
If your order the felpro oem style intake it is thin steel with the valley pan or turkey tray built in. It comes with rubber end seals and sealant. It is all in one and all you need. I would recommend this for a cast iron intake.
Old Mar 4, 2011 | 09:53 PM
RAMBOW's Avatar
Ben
Ok. Thats what i thought, that it WAS the intake gasket, but when i searched at summit, it did not appear when searching for intake gasket, only a search for VALLEY PAN showed it, so i was concerned.
thats what i'll be ordering. Thanks!
Old Mar 5, 2011 | 03:43 AM
Chesrown 67 OAI's Avatar
buy it from advance auto or other parts store --- cheaper than summit. do you self a favor -- do NOT use the end rubbers supplied with it! Fill the area with a GOOD RTV sealant. Those rubbers blow out all the time and/or lose their seal. You will never have that problem if you use only RTV - and besides --- its even easier to install without having to fight those dang rubbers!!
Old Mar 5, 2011 | 06:48 AM
There are 2 styles of intake gasket, 1 is a tray type (3 peice set) for the 330's that did not have a stock turkey tray bolted to the top of the lifter galley and the other is a set (4 peice set) for the blocks that do. Both are available from Fel-Pro.
67442nut
Mar 22, 2015 10:16 AM
1971cutlas
Sep 23, 2013 02:10 PM
ddx77
Aug 20, 2011 10:32 PM
zodiacblueS
Jul 19, 2011 06:02 PM
RAMBOW
Apr 26, 2011 08:48 AM
