1973 olds 455
Your eyes do not decieve you. The 4pc gasket sets are made for racing purposes and that cross-over is not needed. The cross-over is for cold weather driving. If you don't drive in the cold then you dont need it. I have always used the valley pan (also keeps hot oil off the bottom of the intake) with good luck.
If you don't plug the crossover and still use the composition gaskets with the crossover port blanked off, it won't be for long. The exhaust heat will burn through in short order.
Of course, inquiring minds want to know why you don't want to use the stock gasket.
SKINNY IL
May 14, 2010 07:12 AM
