Top of piston
Old Dec 21, 2025 | 12:48 PM
rjh45's Avatar
Top of piston
Anyone know why this piston looks like this. I pulled the heads on my engine to raise the compression and after i cleaned the carbon off the pistons i found 2 pistons that look like this. You cant feel it with a finger nail just looks weird.
Old Dec 21, 2025 | 02:58 PM
cutlassefi's Avatar
I'm guessing this might be a 400E? Otherwise that’s basically a 350 piston but they have the comp distance as the 400E and 425.
Old Dec 21, 2025 | 03:13 PM
rjh45's Avatar
Correct a .060 over 400 E. Has a w31 350 piston.
Old Dec 21, 2025 | 03:58 PM
BillK's Avatar
I think you are asking about the corroded areas, not the type of piston. Pretty normal after even slight use. If you had to scrape carbon off then it is definitely normal. Especially if it has been sitting for a while.
442blue
Apr 18, 2023 04:29 PM
60193W30
Dec 1, 2020 03:21 AM
Andrew7dg
Oct 13, 2016 01:53 PM
jag1886
Feb 12, 2011 11:02 AM
oldsracer67
Dec 16, 2008 01:53 PM
