cam choices. not so much daily drive as rice killer
i have a 70 cutlass supreme. 455 +.030 N crank, C heads. l2323 pistons. 9.5 cr. 200r4 trans with 2500 stall , 4.10 gears with 28 inch tire. looking to build as much motor as possible to stomp some rice. im not too worried about much as long as it runs good, lives long time, and kicks some ***.
i was looking at some mondello cams but i dont know what other would be good. i was told that i could use my bbc roller lifters on the olds. is this true
The venerable Engle 20-22 (226/230) or a Voodoo 60803 (227/233) would both work well in a hot street 468, IMO. Mark (cutlassefi) would be happy to grind one for you. He really loves Engle cams!!
I personally would not mix and match lifters, just get a new set with your new cam and avoid the headaches.
ah64pilot
Suspension & Handling
53
Sep 11, 2012 06:24 PM
