New Oil Pan
Old Jul 24, 2022 | 01:01 PM
Sbradley31's Avatar
New Oil Pan
Just had my 455 rebuilt. The builder put on a higher capacity Toronado oil pan. My thinking is that the original dip stick should give me the proper oil level reading due to fact that it is in relation to the oil level and crank shaft which has not changed. Any thoughts on this would be appreciated.
Old Jul 24, 2022 | 02:08 PM
Duh's Avatar
Duh
Your reasoning is correct. That pan with the correct filter takes 6 qts. After you run the engine and let it cool just verify the dip stick reads correct.
Old Jul 24, 2022 | 02:51 PM
Sbradley31's Avatar
Thanks for your quick response.
Old Jul 24, 2022 | 03:03 PM
I always verify a new setup after an oil change. I use a hand file on the dip stick to scribe a full line if it's off.
Old Jul 25, 2022 | 05:44 AM
Your bigger problem is that the Toro pan is not a great choice for a performance application. The "notch" forward of the sump to clear the front axle shaft traps oil in the front away from the sump, which negates the additional capacity. As for higher capacity pans, one reason to run a larger pan is not to run more oil but to lower the oil level relative to the crank counterweights to minimize windage losses.
Old Jul 25, 2022 | 10:45 AM
cutlassefi's Avatar
^^^^^, not a good choice.
ferndaleflyer
Jun 28, 2016 06:58 AM
dnmfranco
Oct 31, 2013 12:40 PM
808olds
Sep 16, 2010 08:13 PM
MN71W30
Jun 5, 2010 01:37 PM
