OAI Foam
OAI Foam
Hello members - I spent some time searching threads but didn't see an answer. I just converted an L-33 2 BBL to a Q-Jet with OAI air cleaner on a repro aluminum intake. What is typically used to keep the foam in place? double sided tape? Spray tack adhesive? Sorry if this has been asked and answered previously. Thanks for your help.
If you go with the 3M black adhesive, you might want to pick up their special solvent just in case you ever need to do maintenance on the unit, or replace the foam.
That 3M stuff is a very useful chemical glue.
sx455raidercelticfan
Dec 10, 2010 02:48 PM
