65 442 carburetor questions
Old Dec 23, 2021 | 06:11 AM
Gpc1's Avatar
I am running an edelbrock 1406 at the moment on this engine and it’s seems lean to me. I couldn’t use the 4gc carb because I didn’t want to modify the linkage to accommodate the tv cable to the 200r4 transmission. The edelbrock was no problem.
should I try to re jet this carburetor or get a 1411 edelbrock? As for Quadrajets I’m not sure I can use with the transmission
appreciate your opinions thanks in advance
Old Dec 23, 2021 | 07:04 AM
Considering that Olds only used Qjets with the 200-4R, I think you can make that work.
As for the "seems lean", based on what? Did you read the plugs? Do you have a wide-band O2 sensor? Jets and metering rods are a lot cheaper than a new carb, and the only certainty is that the new carb won't be jetted correctly for your application either. On the other hand, 600 CFM is small for an Olds 400. Carb CFM has no relationship to how lean it runs, however. All it effects is max HP.
Old Dec 23, 2021 | 07:43 AM
Gpc1's Avatar
By seems lean I guess what I’m really saying is it just doesn’t feel up to the engine size although it runs great This carburetor was on the 350 I just recently swapped out and was a good match for that motor. It sounds like re jetting the 1406 might be the best option. I do have a quadrajet from a 79 Chevy that might work ?
Or do I need a Qjet from a 455 ?
Old Dec 23, 2021 | 07:49 AM
Your "butt dyno" is about the worst possible way to gauge if the carb is lean or not, especially if it "runs great". Until you have actual confirmation that the jetting is wrong (black smoke, white plugs, or god forbid, data from a real wideband O2 sensor), you're more likely than not to make it worse by playing with jetting. There are a LOT of reasons why it "just doesn't feel up to the engine size", only some of which are related to the carb at all. You REALLY don't want to start messing with jetting without a better understanding of what the car needs in the first place. This is the hundred monkeys with a hundred typewriters scenario.
Old Dec 23, 2021 | 08:40 AM
Gpc1's Avatar
Don’t have a O2 wideband to verify, butt dyno, timing light, dwell meter and such is about all I have ever needed.there is no smoke and plugs look fine maybe I’m just expecting too much. Thanks
Old Dec 23, 2021 | 08:59 AM
67OAI's Avatar
Old(s)GuysRule
Sounds like the 1406 is not enough CFM for the motor. Try the Chev q-jet if compatible with your linkage.
Old Dec 23, 2021 | 09:09 AM
Gpc1's Avatar
I thought it might be not enough cfm , but maybe not. Going to run it for awhile and see. The problem with the Chevy Qjet is the choke set up won’t work with the olds motor that I can see
Old Dec 23, 2021 | 11:21 AM
Not to mention the fact that it will necessitate use of a spreadbore manifold. Installation notes for the 1406 suggest that it's good for up to 502 CI, so I'd continue to work with it if I were you.
Old Dec 23, 2021 | 12:54 PM
Gpc1's Avatar
The manifold problem could probably be overcome with a spacer, but I’m going to keep the edelbrock on there and recheck all my settings again.
Old Dec 23, 2021 | 01:40 PM
Only if you REALLY want to screw up the flow.
Old Dec 26, 2021 | 07:46 AM
67OAI's Avatar
Old(s)GuysRule
Oops! Didn't notice that the manifold was not for a spreadbore carb.
Old Dec 28, 2021 | 11:48 AM
Gpc1's Avatar
i have a 1” spacer on there now to give clearance for the carburetor throttle linkeage from manifold.
Am I screwing up the air flow with it?
Old Dec 28, 2021 | 11:55 AM
A spacer with straight holes that are the same diameter as the holes in the manifold is a minimal flow impact. I'm talking about the crappy Qjet-to-square bore adapters where the holes go sideways. The die cast ones are even worse.
Old Dec 28, 2021 | 12:50 PM
Gpc1's Avatar
I would never consider something like that. The spacer I have doesn’t have the 4 holes but is open.
I don’t know if that matters or not?
Old Dec 28, 2021 | 12:54 PM
It depends on the manifold and your specific engine combo. An open spacer adds plenum volume. That may or may not be beneficial to the engine. And what happens at the mounting flange on the intake? Does it have four individual holes? If so, there's likely a flow disruption there.
Old Dec 28, 2021 | 01:10 PM
Gpc1's Avatar
stock 4 hole manifold so maybe get a spacer with the 4 holes I’m thinking. Also thinner like 1/2” if it will still clear the lineage.another question non carburetor, which vacuum port to use for the distributor. I see most hooked up on the passenger side port which is timed vacuum or the one on the driver side which is full vacuum?
Old Jan 1, 2022 | 12:07 PM
RAG's Avatar
RAG
Greg, I've put a 200-4R on a couple '65's using the 4G carb, just takes some fabrication and brazing.
Old Jan 1, 2022 | 12:27 PM
Gpc1's Avatar
Roger,
Do you still have the carburetor I sent back? I felt guilty about modifying the lineage on such a nice unit.
I’ll buy it back and the correct baseplate if you still have them . Thanks
Gph850
Jun 26, 2021 11:25 AM
Tiger69
Sep 16, 2018 10:22 AM
boese1978
May 24, 2012 06:52 AM
Schober Motorsports
Feb 22, 2010 05:02 AM
72CUTTY
Nov 3, 2007 05:57 PM
