Intake manifold question
Old Nov 25, 2021 | 08:16 AM
tiogatwister's Avatar
Does anyone have any experience with Offenhausers intake manifold for a big block Olds? Looking for any input. As good as stock? Good low end torque? Is the torker a better choice? Just looking for something to put on a mild street build 455.
thank you.
Do you know anything about this intake? Do you know anyone that has used it?
https://lansing.craigslist.org/pts/d/bath-oldsmobile-455-aluminium-intake/7394100848.html
This is the intake I am looking at
Old Nov 25, 2021 | 08:27 AM
RetroRanger's Avatar
72 Olds CS
I think inthe past Joe P has stated the offy is the same as the stock iron intake -25 lbs.
Old Nov 25, 2021 | 08:29 AM
72 Olds CS
https://classicoldsmobile.com/forums...ntakes-123636/
Old Nov 25, 2021 | 08:46 AM
I'm pretty sure that what JoeP has said is that the factory W30 intakes are the same as the iron ones as far as flow. He's also said that the Offy intakes pretty much suck, at least the flat single plane ones. And don't get me started on the goofy dual port versions.
The first question to the OP is, how are you using the engine? Car? Gears? Engine mods? The intake needs to be matched to the rest of the system. For a mild motor, get an E-brock dual plane.
Old Nov 25, 2021 | 08:48 AM
Duh's Avatar
Duh
If your looking to maximize torque that intake is at the bottom of the list as far as I'm concerned. Stock would be way better. You should go for a dual plane.
Old Nov 25, 2021 | 08:55 AM
Thank you all for your quick responses, I do appreciate your input, looking forward to hearing from more knowledgeable Olds enthusiasts.
Oct 19, 2020 10:23 PM
Sep 15, 2019 04:30 PM
sworthy555
Jan 8, 2012 02:00 PM
Stevec
May 14, 2011 06:42 AM
MI455
Nov 5, 2009 02:28 PM
