Pulleys Help
Pulleys Help
I am building a 1971 Olds 442 W30 clone and need some help on water pump selection as well as pulleys. The car does not have A/C nor do I plan to add it.
I bought new pulleys for it but not sure they are correct. Here's what I have: 2 groove crank pulley "KJ", 2 groove water pump pulley "KM", and 1 groove P/S pulley "KC". I now have to select a water pump and I was leaning towards the high-flow FlowKooler model #1775 that's the long 6" shaft model. I will be using an aftermarket radiator too with possibly electric fans vice the clutch fan OEM system.
Will these components I mentioned work together and provide me the high flow capacity I am shooting for? If not, what do I need to change or buy?
Thanks.
Thanks.
