400 E block 400 build
Old Jul 27, 2019 | 07:49 AM
JIM'S w30's Avatar
Thinking of building a 400 E block motor with Edelbrock performance heads need advice on the cam want something big and lumpy bottom end will be stock bore and balanced also it will be going into a stick car
Old Jul 27, 2019 | 08:11 AM
RandyS's Avatar
Suggest you reach out to member 'cutlassefi'. He can suggest (and supply) a really good cam for your application. He can also provide guidance on any and all of the other parts you may need for your build.
Old Jul 27, 2019 | 08:39 AM
X2. Can't say enough good things about Mark.
Old Jul 27, 2019 | 12:57 PM
OLDSter Ralph's Avatar
Find out what cam bank angle block you have. I think '65 is 45 degrees, '66-67 is 39 degrees. The 400E is the better "400 engine" to build for performance.
Old Jul 27, 2019 | 03:41 PM
cutlassefi's Avatar
You’re making me blush😎
I try, thanks gentlemen.
Op- you mentioned std bore, I’m guessing then that you’re not touching the bottom end?
If not then we’ll have to work with the stock comp ratio. Is it the 10+:1 version? That will dictate the cam choice to a great degree.
Thanks.
Old Jul 27, 2019 | 05:16 PM
JIM'S w30's Avatar
Thanks.
ya don't want to touch bottom end and yes 10+:1 looking for a nice lumpy cam kinda like a w30 cam but bigger
Old Jul 27, 2019 | 05:21 PM
Kennybill's Avatar
1965 400 is a B block, 45° camshaft. E block is 1966/1967. Seeing as how your going aluminium heads would you be interested in a 425 D of a 455 F block/engine trade? If you want to discuss it PM me. Ken
Old Jul 27, 2019 | 06:38 PM
JIM'S w30's Avatar
I already have a 455 and no don't want to trade the E block is going into my 68 w30 so I can beat the hell out of it and enjoy the high rpm' and store my original engine
Old Jul 27, 2019 | 08:14 PM
1965 400 is a B block, 45° camshaft. E block is 1966/1967. Ken
Thank you, I am better informed.
Old Jul 28, 2019 | 05:29 AM
cutlassefi's Avatar
enjoy the high rpm'
FYI- That has little to nothing to do with the displacement. My dyno guy does 858ci mountain builds that rev to 8800rpm.
If it’s a 39 degree block then you’ll be fine with the Edelbrocks. But if it’s a 45 then you’ll need to machine the pushrod guide holes.
I’d do 232/240@.050 on a 108 Erson. Lift is in the .560 range to best use a good cyl Head.
Hope this helps.
Old Jul 28, 2019 | 07:26 AM
Kennybill's Avatar
I've got 1967 D block C headed 425, 39° cammed, similar to E engine but 25 cubic inches larger, same forged crankshaft, rods. Either way if engine is seeking high rpms you should get better connecting rods. Mark can fill you in on a better 7 inch rods already sized for Olds or machine crank for a better selection of rods. If you are making a "high" winder that's the way to go. Kind of like opening a can of worms.
JIM'S w30
Apr 10, 2019 04:23 PM
Oldsragger
Jan 7, 2015 06:13 AM
Stevec
May 30, 2012 06:35 PM
ut442
Jan 24, 2012 04:22 PM
442scotty
Mar 3, 2011 07:37 PM
