couple questions
Old April 6th, 2009, 10:13 AM
Horsepower Junky
bigde53's Avatar
couple questions
I just got my 455 mounted this weekend and was wondering.
1. I am putting headers on and need to know the best kind of gasket to use?
2. I have a torker intake is it worth pluging the crossover?
I just read about blocking the heads crossover, Im not taking them back off for that so is it the same benafit doing the intake instead? Thanks Darin
bigde53 is offline
Old April 6th, 2009, 12:27 PM
1. I like embossed copper gaskets.
2. Blocking the crossovers in the heads serves two purposes. First, it allows you to fix a flow disruption that is caused by the stock passageway. Second, it allows a cooler intake mixture. Blocking the crossover in the intake does only the latter. Frankly, unless you plan to race the car and take careful records on performance and jetting, I doubt you'll see a difference in performance.
joe_padavano is offline
Old April 6th, 2009, 12:51 PM
1964f-85's Avatar
I used the compressable copper gaskets from Summit, with copper high heat RTV, that would hold up for the summer before having to reapply the rtv sealent. Unless your planning on going racing, I wouldn't put on headers, they leak no matter what. I just swapped out my headers for W & Z 442, true exhaust manifolds. As far as the cross over, I have run my Torquer with and without an I haven't noticed any difference in how it runs. By the way, if you use the copper gaskets, open up the bottom of the out side holes on the gasket into a "U" shape, if you do develop a leak you can pull the gaskets without having to unbolt the whole header, just loosen the outer 2 bolts and remove the inner 3, the gasket will slip out the top.
1964f-85 is offline
Old April 6th, 2009, 02:13 PM
That's a good trick for any header gaskets. If the gaskets I have aren't already cut like this (some are) then it's the first thing I do. That lets you get the header bolted up first without having to mess with the gasket at the same time.
Old April 6th, 2009, 02:22 PM
kaz442's Avatar
I use Mr Gasket Utra Seals on both my cars with headers. No leaks, but I'm using hooker super comps. Maybe some of the cheaper headers may be prone to leaks. JKaz
kaz442 is offline
Old April 6th, 2009, 10:14 PM
Horsepower Junky
bigde53's Avatar
Thanks guys
I think I will leave the intake the way it is and I was leaning toward the copper gaskets for the headers. I want to head down to summit racing this week anyway. And that is a great tip on the gasket thanks again. Darin
bigde53 is offline
Tvan
April 10th, 2012 02:06 PM
Kwish
June 29th, 2009 02:42 PM
1973oldsomega
March 23rd, 2009 08:31 AM
74omega
Drivetrain/Differentials
July 7th, 2008 09:46 PM
Rallye469
March 24th, 2008 09:29 AM
Quick Reply: couple questions
