Distributor won't seat in 1970 455
Trying to get my 1970 455 to fire. The distributor doesn't seat all the way down. The oil pump drive rod may not be letting it. Not sure. I fit the distributor into another motor and it fit fine. If the drive rod is the problem what is the fix? If the distributor gears are he problem then what is the fix? Thanks.
chris83
August 18th, 2012 01:47 PM
