valve springs
valve springs
I was stripping down a set of C heads and found that one head has single exhaust springs and double intake ones, the other is all double springs, I thought this was weird. Then I found the one with all doubles was certainly taken apart before because the valve seals were newer. I am wondering what springs I should put where, I am taking J heads off the 73 455 to put the C's on. The J springs are all single, should I use all the singles on the C's to match what the cam had before or should I have some of them as double springs.
I appreciate any information I can get
are you sure they are double ? or are they single with a damper in the center.
A double spring has a coil of inner and outer.
A single spring can have nothing in the center or a flat spring steel inner as a damper.
Gene
Gene
Boy do I feel stupid now, I get what you mean, I completely forgot that, Im fairly new to this and haven't fully had every thing sink in. I appreciate the information Gene. So they are not double springs they just have the inner damper. So what should I do, does it matter that the original heads did not have them? Which springs should I go with here? Thanks again
Well I don't have a nearby shop that I have heard good things from, in the case of the dampers in the middle, will they have any effect whether they are there or not? Its just a stock 455.
So what is the down side to the op sticking these C heads with dampeners on a 1973 engine?I am not saying to change the springs off the j heads to the c heads!
bigjaythe1st
Suspension & Handling
May 8, 2012 05:45 PM
1acesmith
Aug 11, 2011 11:03 AM
