What cam is this?
Acceleratii maxim rapidus
What cam is this?
Hi all.
I found this cam at a clearance price and was thinking i may as well swap the cam out at the same time i change the J heads for the C's i procured along with a dual exhaust.
unfortunately i know nothing of 'duration' and 'rocker arm ratio's'.. hoping someone would chime in with an explanation as to what cam this is eg; mild, street or race??
just need to know if it suits my needs ie, occasional driving with a bit of hoon element, sleeper style..
copied from the sheet in the box,
Crane Cams PowerMax Hyd Camshaft/Lifter Kit # 803902 B1Q3**
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 260/272, Lift .456/.484, Oldsmobile, 455 V8, Kit
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,200-4,800
Engine bank angle 39 degrees
Intake Duration at 050 inch Lift 204
Exhaust Duration at 050 inch Lift 216
Duration at 050 inch Lift 204 int./216 exh.
Advertised Intake Duration 260
Advertised Exhaust Duration 272
Advertised Duration 260 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.456 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.484 in.
Valve Lift with Factory Rocker Arm Ratio 0.456 int./0.484 exh.
Lobe Separation (degrees) 112
Computer-Controlled Compatible No
Lifters Included Yes
Lifter Style Hydraulic flat tappet
Valve Springs Included No
Retainers Included No
Locks Included No
Valve Stem Seals Included No
Timing Chain and Gears Included No
Assembly Lubricant Included Yes
Pushrods Included No
Rocker Arms Included No
Gaskets Included No
Valve Springs Required Yes
**Not Legal For Sale Or Use On Streets Or Highways
I choose to ignore the last statement...
Locks Included No
Gaskets Included No
I don't know what you are looking for, but that is a nearly stock cam in terms of performance; more a mileage cam. Personally, I wouldn't waste the time or money on it unless my cam was worn out and I wanted a slightly updated stock type cam.
Thanks for the replies.
I am looking for something a bit more performance orientated without going over the top, not too worried about economy. The car only gets driven for fun.
I will keep looking.
Erson TQ20 would be 214/214@.050 with .478 lift. Whatever you do you'll probably need different springs put on the C heads.
And gotta ask, you have a Ford 289 in your El Camino? Or a bored 283?
