Valvetrain noise
Valvetrain noise
Hi all.
So I've got about a 1000 miles on 455 rebuild. My question is that I've started noticing a slight ticking noise when driving. It doesn't always happen but when it does it happens just before engine comes down to idle like around a 1000 rpm. And on for a brief moment. Pulled valve covers and checked everything and reset lash but everything was just fine. Could I possibly have a bad hydraulic lifter?
Hi -I had a valve train noise in my 455 last year, my engine had less than 500 miles on it, I had adjusted the valves several times, same thing, changed my header gaskets, same, pulled the motor back out and brought it back to my machine shop-he tor the engine down,nothing, until he was reassembling, in the intake there were these metal plugs to close off the heat passages, one was loose causing a exhaust leak in my intake, removed them no issues for a year now, carl
That valve train noise drove me crazy- it wasn't the lifers bleeding down or the push rods hitting the guide plates- or a oil pressure problem -I must have had the valve covers off 10 times -they are metal plugs that came from mondello before the thin metal gaskets that are used now. One of them was loose.
fastcutlass1980
Apr 17, 2013 05:12 AM
These are the intake plugs
