valve covers & breathers
Old Nov 6, 2014 | 12:13 PM
rpinnt's Avatar
As I get closer to finishing the engine I keep running into expensive details. I first had tall, plain chrome valve covers and decided I didn't want chrome. I then went with extra-tall cast script covers that were too tall and would not fit under a stock brake booster. Now I have vintage M/T valve covers that wouldn't clear the rockers. A set of billet spacers seems to have fixed that.
From what I've read it would be beneficial to have a PCV and a breather. The M/Ts still have the "knock-outs" (?) in place. Do you remove them with a hammer and punch or drill them out?
Old Nov 6, 2014 | 03:27 PM
lemoldsnut's Avatar
what rockers are you running. M/T clear harlen sharpe rockers
Old Nov 7, 2014 | 06:57 AM
rpinnt's Avatar
They were from Mondello for aluminum heads.
Old Nov 7, 2014 | 07:17 AM
TripDeuces's Avatar
I think I tapped mine out with a ball peen hammer and then dressed the edges.
Old Nov 7, 2014 | 12:42 PM
rpinnt's Avatar
I hit it a couple of times but chickened out after no noticable effect. Do they get pushed in (which is what I tried) or from inside out?
Old Nov 9, 2014 | 06:47 AM
TripDeuces's Avatar
I hit mine in yes. You could also drill it out along the edges on the back side which would weaken the parting line then hit it from the outside.
Old Nov 9, 2014 | 07:28 AM
Octania's Avatar
drill and Dremel cutter?
Old Nov 12, 2014 | 12:36 PM
rpinnt's Avatar
The hammer on ball peen hammer worked great. Hit the edge with a die grinder and the edge smoothed out nicely. Thanks for the help.
Old Jan 7, 2015 | 03:51 PM
rpinnt's Avatar
I had the valve covers powder coated with a silvery finish to match the aluminum heads. I still am planning on painting the recesses gold to match the block and polishing the fins.
I did order an aluminum breather and PCV. The knocked out holes on the valve covers are D shaped. Will a round grommet work or do I need different ones? I hate getting parts that I don’t need that costs too much to ship back. Anyone have a suggestion or source for grommets that will work?
Old Jan 7, 2015 | 04:05 PM
The round grommets don't work but the D shaped are available, check your dimensions.
Old Jan 7, 2015 | 04:36 PM
Octania's Avatar
$30
both
claims to be factory parts
you will know if they are, because they will fit and work right
http://www.ebay.com/itm/NOS-OLDSMOBI...63ed65&vxp=mtr
Old Jan 8, 2015 | 05:02 AM
jpc647's Avatar
I got mine at napa. I ordered the online and picked up in store.
I try to stay away from online and 'restoration' shops as much as possible. Local stores let you see the parts, etc, and if they don't work, you don't have to pay for return shipping.
Old Jan 16, 2015 | 01:19 PM
Oldsragger's Avatar
Can anyone see if this is "tall" type valve covers, get mine from ebay today but they look so small.. i can see its about 7.5cm total (its about 2-61⁄64in?) ,but they should be 3-3/8" ?! the 307ci covers looks same height...
Old Jan 16, 2015 | 04:00 PM
bluecab's Avatar
Mostly Gristle
That looks like a short cover to me.
Old Jan 18, 2015 | 01:57 PM
68 D88's Avatar
I use the following when I run the M/T valve covers:
Grommet - Dorman Part No 42067 + a push-in breather
Grommet - Dorman Part No 42314 + a PCV - Wells Part No PCV76
OldSchoolMuscle71
Jan 2, 2013 07:22 AM
66-3X2 442
Jul 13, 2011 02:09 PM
88hurstolds
Dec 23, 2010 09:24 AM
agtw31
Apr 25, 2010 09:08 AM
