Vacuum advance canister.
Old Aug 9, 2014 | 05:51 PM
ziff396's Avatar
Okay, so I found mine is not working and has failed. I bought a new canister that is adjustable. I am not a distributor guy, and I need instructions on how to replace it. It looked simple,(and probably is), however I removed the cap and rotor (HEI), removed the mounting screws, and their is no play to remove the rod to the advance unit. It is underneath.
So what is the easiest way to replace this? I just stopped waiting for your advice. Thanks
Old Aug 9, 2014 | 06:25 PM
Just push the rod out of the hole in the advance plate with a screwdriver or something and pull the advance unit out.
Old Aug 10, 2014 | 04:47 AM
ziff396's Avatar
Thanks Eric. I ended up having to place the screwdriver underneath and twisting it to release it as the rod bottomed out the other way. Anyways, all fixed!
defiant1
Aug 4, 2014 09:15 PM
pcard
Feb 11, 2013 05:09 PM
Steeb
Apr 8, 2009 06:06 PM
KQQLCAT
Oct 20, 2008 07:21 AM
KQQLCAT
Sep 2, 2008 10:12 AM
