Timing marks again
Old Jun 19, 2018 | 08:43 AM
67Rocket's Avatar
Timing marks again
Just to be sure, on a new build, with the timing marks aligned, crank at 12 and cam at 6, rotor needs to be on number 1. Thanks for your patience.
Old Jun 19, 2018 | 09:13 AM
cutlassefi's Avatar
I believe that’s for number 6. But don’t sweat it. Once it’s together just bump it over with the number 1 plug out and your finger in it. When it pushes your finger out it’s at tdc compression.
Old Jun 19, 2018 | 02:14 PM
Mark is correct. Chevy motors are on the compression stroke in no. 1 with the marks at 6-12. For Olds motors compression on no. 1 happens when the marks are at 12-12. As Mark points out, I don't understand why people worry so much about this. Put it together, check for compression in no. 1, and drop in the distributor. We spend more time talking about it than it takes to just do it.
Old Jun 19, 2018 | 05:47 PM
67Rocket's Avatar
After decades of working on Chevys, please excuse my confusion. So I am rotating to 12 and 12 and installing the rotor to number 1 cylinder. Thanks to everyone.
Old Jun 19, 2018 | 06:12 PM
I believe the installation is same for Chevy as it is for Olds, You install the chain with the crank at at 12 and cam gear at 6. That puts the distributor pointing to #6. Rotate the crank one full turn and the crank is again at 12 and the cam is at 12. That puts the distributor at #1. The firing order for Olds is the same as Chevy.
Old Jun 20, 2018 | 07:04 AM
67Rocket's Avatar
Thanks again
Old Jun 20, 2018 | 08:03 AM
edzolz's Avatar
But isn't the cap wired counterclockwise for Olds?
Old Jun 20, 2018 | 05:16 PM
Yes, but that doesn't change the firing order. It is still 1-8-4-3-6-5-7-2 for both.
Macadoo
Nov 10, 2017 08:23 PM
Oldsmobiledynamic66
May 27, 2015 10:10 AM
Jacob Wilson
Nov 19, 2013 08:20 PM
RonzBoyz4
Oct 18, 2013 11:46 PM
Gbobby
Feb 4, 2009 06:31 AM
