Timing Chain sets
Old Oct 12, 2023 | 04:09 PM
Chuxter's Avatar
1970 Cutlass Supreme
Timing Chain sets
Needing to purchase a new timing gear set. Everyone is out of the cloyes set. Thoughts on comp cam sets or auto zone sells a set from SA. Thoughts and opinions please.
Old Oct 12, 2023 | 04:55 PM
I got the Comp Cams 2113 double roller timing set in the spare 455 I had built. It works great. I had the machinist assemble the short block and I assembled it the rest of the way.
https://www.summitracing.com/parts/cca-2113
Old Oct 12, 2023 | 05:03 PM
4speed455's Avatar
I used the Edelbrock one on my build.
https://www.summitracing.com/parts/e.../442/year/1970
Old Oct 12, 2023 | 06:14 PM
BillK's Avatar
If you are just looking for a stock set the SA Gear one will be fine. They are one of the larger manufacturers. I think I might have a Cloyes set if you can wait but SA should be fine.
Old Oct 12, 2023 | 07:13 PM
cutlassefi's Avatar
You want a good one or just an average 3 keyway?
Old Oct 13, 2023 | 09:34 AM
Chuxter's Avatar
On the double roller sets is there any problem with clearance on your fuel pump lobe?
Old Oct 13, 2023 | 09:52 AM
I've always ran a mechanical fuel pump and I never had a problem with the eccentric activating the pump or interfering with the timing chain.
jensenracing77
Feb 16, 2023 05:47 PM
Transam461
Feb 11, 2020 11:50 PM
Smitty275
Jul 19, 2014 01:02 AM
costpenn
Feb 24, 2013 12:03 PM
ihengineer76
Jul 28, 2012 04:09 PM
