timing advanced = white smoke
I noticed a ping noise at about 95 mph on the highway (4100 RPM). I let off the gas and white smoke came out of the exhuast. After 10 seconds no more smoke and car ran fine. I went home and checked the timing and it was at 17 (not total timing). I backed it off to 14 and will test again tonight. HEI system. ( I think the distributor has 20 degrees timing)
1968 455 with C heads mild cam, single plane intake, and Holley 750 DP.
I assume that smoke was related to too much timing advance?
Funny thing is the car had no ping until I was at 95 MPH 4100 RPM. I assume this is when the distributor had no engine vacuum holding it back?
OK Timing is at 14 now and no more ping at high speed.
I still get some blue smoke when I reach high speed and high rpm. I assume this is the PCV valve working at WOT. The crank case pressure builds and the oil gases get sucked into the manifold and burnt off.
I will test that tonight.
I will disconect the PCV from the vacuum source. If smoke still happens I have a ring problem.
Although it is really not a problem below 100mph which will only occur at the end of the 1/4 mile run.
A compression test will also reveal an ring issue.
The white smoke at 95 mph is probably an over rich conditon, do to timing and carb settings. Was it a gentle climb or full WOT? If it was a gentle climb, perhaps your vacuum canister is in need of a limiter.
You will not have any vacuum to the dist @ WOT. Set your distributor for total timing @ around 34* - 36* @ 3500 RPM with vacuum disconnected, and see where your initial winds up.
It was full WOT. Initial timing is currently 14 @ 700RPM with no vacuum to distributor.
I will check and see where the total timing is @ 3500. I will do this with distributor vacumm on. Correct?
Other than that what I mentioned early (smoke @ 100+ when let off gas)the car runs great. Super responsive and no lack of power.
Incorrect.
Vacuum advance should be disconnected.
Wait. I must have missed that.
The smoke happened when you let OFF the gas?
Sounds more like loose valve guides to me.
