throttle no workie!
Old Aug 12, 2013 | 12:54 PM
imcgm's Avatar
'67 Delmont Convertible
throttle no workie!
ok, I need a little HELP! my throttle broke inside the engine compartment. some big round thingy with a couple of wires attached to it. can anyone give me some direction so I can buy and replace
I attached a pic, thanks in advance!
Mike
Old Aug 12, 2013 | 01:19 PM
fourtwenty's Avatar
year make and model my friend would help cheerio
Old Aug 12, 2013 | 01:23 PM
RetroRanger's Avatar
72 Olds CS
what kind of car year make model and engine size
Old Aug 12, 2013 | 01:27 PM
Looks like a 66 or 67 Cutlass switch pitch assy for an ST300 or T400 SP. That controls your passing gear and torque convertor. One of the guys may have one, and some members have successfully repaired theirs.
Old Aug 12, 2013 | 01:44 PM
imcgm's Avatar
lol, sorry :/
1967 Olds Delmont 455
dont hink its fixable, it snapped right at the base...
Old Aug 12, 2013 | 02:11 PM
I think the same part was used in a lot of models. Someone ought to have one.
Old Aug 12, 2013 | 02:33 PM
Originally Posted by imcgm
lol, sorry :/
So that's not the original engine (not that it matters for this problem)
Yeah, see, with that 455, you don't need to slam the throttle as hard as before.
Seriously, what part broke? If it's a steel bracket, that's easily welded. If it's the aluminum housing, it might be difficult to weld correctly.
Old Aug 12, 2013 | 03:00 PM
imcgm's Avatar
I am hoping to have time to take it apart tonight or tomorrow, but it appears to ne the base of the round thingy (whatever that is) switch pitch assembly, is what OLDCUTLASS said, sound right?
Old Aug 12, 2013 | 08:30 PM
nsnarsk65cutlass's Avatar
Yes thats the switch pitch detent for the trans,maybe try posting in parts wanted section.
Old Aug 13, 2013 | 08:20 AM
No. The "switch pitch assembly" is a solenoid valve and associated plumbing inside the trans. This is the electrical switch that activates both the switch pitch solenoid and the separate kickdown solenoid (which are why the switch has three wires instead of two).
Old Aug 13, 2013 | 08:44 AM
I was going to write "switch pitch switch and passing gear switch assy" but thought it might sound redundant.
Old Aug 13, 2013 | 10:09 AM
imcgm's Avatar
Joe, do you know where I can buy one? what is the name of the part?
thanks everyone, hopefully I can find one rather quickly...
Old Aug 13, 2013 | 11:03 AM
Oldsmaniac's Avatar
There should be lots of these around as just about all 65-67 b bodies used this part. Used though is your only choice as there are not reproductions. Thing is to see why it snapped. I broke one once trying to snap back the secondaries that would stick open on the Holley spreadbore. Usually a forceful quick tromp on the gas pedal would do it. You need to check that when the gas pedal is all the way down there is not any stress on the throttle rod.
Old Aug 13, 2013 | 11:58 AM
Only Olds and Buick used the switch pitch trans, and some cars used a switch on the intake that attached to the carb arm instead of on the firewall. Unfortunately, since A-body cars are more popular, you see those switches for sale. I can't say that I've ever seen one for a B/C-body advertised.
Old Aug 13, 2013 | 12:35 PM
imcgm's Avatar
so I need to post "switch pitch trans" for a B body in parts wanted? does that sound right? & thanks again for all the help guys!
Old Aug 13, 2013 | 12:49 PM
OK, one more time.
If you post an ad for a "switch pitch trans", you're going to get this:
You want a throttle kickdown switch for a switch pitch trans.
Old Aug 13, 2013 | 01:34 PM
Oldsmaniac's Avatar
A quick ebay search found this. From a Jetstar 330 car but I am guess ing it would be the same. http://www.ebay.com/itm/1966-Oldsmob...70351b&vxp=mtr
Old Aug 13, 2013 | 01:58 PM
He say's it was not checked, which means it may not work.
Old Aug 13, 2013 | 02:33 PM
Oldsmaniac's Avatar
True but a non working kickdown/switch pitch is better than not being able to drive the car at all.... When these snap you cannot use the accelerator.
Old Aug 13, 2013 | 03:59 PM
imcgm's Avatar
you are RIGHT about that THANKS!!
Old Aug 29, 2013 | 10:00 AM
imcgm's Avatar
thank you all!
I am back up and running!!!!
Old Aug 29, 2013 | 10:03 AM
imcgm's Avatar
oh, and if anyone is interested I can post a better pic of where that part failed..kinda weird how it snapped right at the base....
thanks again everyone!
defiant1
Feb 4, 2020 08:53 PM
salisbury99
Jul 5, 2008 05:26 PM
rayvera
Ninety-Eight
Feb 16, 2007 12:33 PM
66starfire
Dec 21, 2006 01:57 PM
1964 oldsmobile 442
Sep 5, 2006 11:19 PM
