Sunday drive
Old Mar 20, 2011 | 10:41 AM
panos's Avatar
Sunday drive
A short blast after i installed the 300+ ignition box, rejetted the carb and adjusted timing,only problem that i have is that i cant attach th vacuum advance because strange things happens like it shoots from the exhaust at part throttle so i left it out for now,base timing is 12btdc and total 30btdc at 3000rpm.
http://www.youtube.com/watch?v=VhvY757AhCs
Old Mar 20, 2011 | 01:47 PM
citcapp's Avatar
Very cool, do you have the vacuum advance connected to ported vacuum at the carb or to manifold vacuum. Should be to ported vacuum at the carb
Old Mar 20, 2011 | 01:54 PM
panos's Avatar
I had it on manifold vacuum,i can try ported but im a little afraid that is gonna ping,this motor doesnt seem to like too much advance
Old Mar 20, 2011 | 02:32 PM
citcapp's Avatar
Try the ported and let us know what happens, may have to change the spring rates in the distributor
Old Mar 20, 2011 | 03:09 PM
71 Cutlass's Avatar
One of None W-31
interesting video on ported vs manifold vacuum. Old timer says always use manifold vacuum not ported b/c that's the way all muscle cars were always done until "Emssion engines" requirements were placed on engines.
http://www.youtube.com/watch?v=Gj2ut...BD20013E579A63
Start at 40 second mark.
Old Mar 20, 2011 | 06:45 PM
Lady72nRob71's Avatar
Mine is 'improperly' set on manifold vac but she runs too good to move anything....
Old Mar 20, 2011 | 08:55 PM
71 Cutlass's Avatar
One of None W-31
Or, "properly" set up as the guy in the video believes.
Old Mar 21, 2011 | 12:59 AM
panos's Avatar
That is a big debate that is going on for years,im for manifold but thats just me,maybe it depends on the motor? who knows,but just a question as we all know when you set your initial you have to unplug the vacuum right? if the right way is ported vacuum why should you do that? there is no vacuum at idle on the ported side and it doesnt change a thing since the throttle blades are closed
Old Mar 21, 2011 | 05:09 AM
Right!
I created a debate on this point several years ago.
Most of the "old timer" mechanics said to use manifold vac. I knew their collective experience must say something.
I think there are a little less emissions when used on ported vac (or something like that).
Old Mar 21, 2011 | 08:03 AM
panos's Avatar
Here is an intresting article
https://classicoldsmobile.com/forums...tml#post247099
Old Mar 21, 2011 | 09:10 AM
71 Cutlass's Avatar
One of None W-31
I've posted that article here before as well. Just another confirmation that cars have used full manifold vacuum, until the gov. wanted less emissions polluting the air (1973 or so) so ported vacuum was mandated by the gov. Ported vacuum is about polluting the air less, not the performance of a vehicle.
Old Mar 21, 2011 | 09:35 AM
cutlassefi's Avatar
I disagree. If your distributor is curved correctly then the vacuum advance is solely to optimize the spark timing for light load cruise for the most part.
Even on my EFI at normal operating temp the spark map reflects an increase in timing at cruise only. However there are benefits by being able to add spark for cold running as well as removing it at various loads and rpms here and there.
Old Mar 21, 2011 | 05:30 PM
ziff396's Avatar
Mine hates ported vacume. I have to really crank up the idle for it to run, and still is to rough. Plug into manifold vacume and it runs great. Aftermarket cams etc. change alot of things. I'm set up @17 degrees initial and 37 all in @ 3k. Edelbrock heads. Lunati Vodoo 60803. From what I have heard and have found, Edelbrocks like a lot of timing. Actually @20 degrees initial it starts at almost the bump of the key, however, I am not that brave to leave it that far ahead. No ping to date. JMO. EFI, I respect your experience. Just had to add mine with my engine.
Old Mar 21, 2011 | 07:50 PM
71 Cutlass's Avatar
One of None W-31
I'll stick with what works best...and with the old timers who lived "back in the day."
RetroRanger
Sep 14, 2013 06:16 PM
Kennybill
Jul 16, 2009 06:45 PM
65az
Mar 30, 2009 11:26 AM
Oldsmaniac
Nov 22, 2008 06:01 AM
$tryker
Jun 11, 2008 02:55 PM
