stuck lifter help
Old Sep 1, 2012 | 06:43 AM
jensenracing77's Avatar
stuck lifter help
this engine has not ran since the mid 80s. i primed it up with a drill till i had oil coming from most of the rockers. i got it started and one of the lifters is stuck. one that didn't have oil coming out while i was priming. is there any tricks to getting them to free up without pulling the intake? i am sure i will have to but thought i would ask. i only ran it for a minute, i am thinking i will run it longer and see what happens.
Old Sep 1, 2012 | 08:55 AM
rocketraider's Avatar
Oldsdruid
The factory shop books recommended whacking the rocker arm on the offending lifter with a mallet while engine was running to free a stuck lifter or quiet it down.
But, since this one is apparently related to sludge/varnish/lack of use, dump a quart of Rislone or Marvel Mystery Oil, or even some transmission fluid, in it and let it run a few minutes to see if it will free up.
Which engine is this Eric?
Old Sep 1, 2012 | 09:45 AM
Take the valve cover off, remove that rocker assy, and you can lift the push rod out a little bit and spray a $hit load of penetrating oil down through the pushrod hole. Reassemble the rockers, and hand turn the engine and tap on the offending rocker with a plastic mallet. That may break it loose!
When you pulled your valve covers off, was there a bunch of CA Ca in there?
Old Sep 1, 2012 | 12:37 PM
DeltaPace77's Avatar
Know years ago as kid, would have older cars with stuck hydraulic lifters, and some solvent additives for this purpose would help. Maybe Risilone, but know it looked like a quart of paint thinner. Was only intended to run for a couple days, then the whole oil pan needed to be drained out. Sorry, as awhile back, but did free up the stuck lifters quite well.
Old Sep 1, 2012 | 01:30 PM
stetzie's Avatar
stetzie
Lacquer thinner will work for this. It will dissolve varnish like buildup faster than anything else I know of. Flood the lifter through the push-rod (if hollow push-rod) and tap gently and it should free up the stuck lifter. Years back I used a mixture of 2 quarts lacquer thinner, 2 quarts kerosene and 2 quarts oil. Let engine run at a little above idle speed but fast enough to maintain some oil pressure. You shouldn't have to run it long for this.
My 2cents worth.
stetzie
Old Sep 1, 2012 | 02:04 PM
... or just put 50 or 100 miles on it, and it'll probably free up on its own.
Old Sep 1, 2012 | 02:12 PM
RocketPower442's Avatar
try marvel mystery oil
Old Sep 1, 2012 | 02:51 PM
i think this lifter is stuck on the very bottom of it's travel. it is very clean under the valve covers. i ran it for another 5 minutes till i had oil coming out all the rockers and it is still stuck. that rocker make all kinds of racket. i am going to change the oil anyway so i may run some penetrating oil down the push rod and leave it till tomorrow. thanks for the ideas.
this is the engine in my 70 W-30 i started the other thread on.
Boilerz25
Apr 11, 2014 07:05 AM
1957 Super 88
Jun 10, 2013 09:55 AM
1BOSS83
Apr 8, 2013 05:20 PM
Tony72Cutlass'S'
Aug 8, 2012 07:00 PM
silverriff
Body work
Jul 23, 2010 01:01 PM
