Spark Plugs
Old Oct 11, 2009 | 01:58 PM
My442's Avatar
Spark Plugs
I wanted to tell everyone about my experience with spark plugs.
I have tried NGK, Champion, Accel, AC Delco, and Autolite plugs in my 70 442 with a 455.
Out of all the plugs tried, the Autolite Platinum #85 worked the best. The engine idled and ran best with them.
The AC Delco RapidFire plugs also worked well, but are more expensive.
My ignition combo:
Factory distributor recurved, with a Pertronix Ignitor
Pertronix coil
Taylor wires
Blur Streak car and rotor
Autolite platinum plugs
Works great.
Old Oct 11, 2009 | 02:24 PM
WTony's Avatar
Do you know if these #85's will work with Edelbrock aluminum heads? Have the same coil and pertronics as you. Thinking of going to an MSD box. Any thoughts?
Old Oct 12, 2009 | 05:34 AM
My442's Avatar
I am not sure, but I think Edelbrock heads take a different plug.
Old Oct 12, 2009 | 08:37 AM
citcapp's Avatar
Edelbrock heads require a 14mm x 3/4" reach gasketed spark plug and depending on application the heat range will vary from Champion RC-9YC to RC-14YC or equivalent. RC-12YC is recommended for street use
The MDS Box will give you a hotter spark and you will have to increase the plug gap (the MDS directions give you the perimeters for the gap
Old Oct 12, 2009 | 03:02 PM
WTony's Avatar
So the plugs I need are a metric thread? Or the Champion RC-12YC is what I need? I have Accel in there now that I got when I bought the heads but am not happy with them.
Old Oct 12, 2009 | 04:36 PM
citcapp's Avatar
Correct on the thread. They do not have to be champion, you can cross reference to any brand. If its a street driver the just go with the equivalent to the champion RC-12YC in your prefered brand
bob p
Apr 10, 2015 01:55 PM
maquis1431
Sep 27, 2008 10:42 AM
65Delta88
Sep 11, 2008 10:13 AM
KQQLCAT
May 6, 2008 08:18 PM
The_Jeremiah
Jan 26, 2008 01:56 AM
