Spark plug gap with MSD system dist 6 al box
Old Jun 2, 2023 | 03:42 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
My 1970 455 has MSD 6 AL box with MSD distributor electronic ignition.
I was wondering if the spark plugs were gapped
correctly at 35 I thought it’s supposed to be 45 with electronic?
Old Jun 2, 2023 | 04:57 PM
BillK's Avatar
I think MSD usually recommends .035 MSD is not the same as GM HEI which usually specified larger gaps.
If it runs good, leave it alone
Old Jun 2, 2023 | 06:17 PM
cutlassefi's Avatar
Agreed, but two totally different ways of firing the plugs.
Old Jun 2, 2023 | 06:38 PM
Olds Specialist LOL
it runs pretty good. I honestly thought MSD was electronic ignition. I thought maybe the guy made a mistake I believe you guys.
well, I got them at 40. I did have a problem with the car running on a little bit like it needs higher octane than 91. Not sure if it has domed pistons, but sounds pretty Cammed.
Old Jun 2, 2023 | 06:39 PM
fleming442's Avatar
X3. You could tighten it up a touch if it's higher compression, like 11 or 12:1, but you'll be fine at 035. Bigger gaps just stress components.
Old Jun 2, 2023 | 08:18 PM
Olds Specialist LOL
ok thx 35 it is
Old Jun 2, 2023 | 09:23 PM
I think the plug gap would be more dependent on the coil used than anything else.
Old Jun 2, 2023 | 09:29 PM
OLDSter Ralph's Avatar
i think the plug gap would be more dependent on the coil used than anything else.
x 2
Old Jun 2, 2023 | 09:51 PM
Olds Specialist LOL
Msd blaster II
Old Jun 2, 2023 | 10:29 PM
fleming442's Avatar
Tighten it up to 032 or 030 if it makes you feel better, but you're still good in my opinion
Old Jun 3, 2023 | 03:31 AM
rickw30's Avatar
I run my 6al and blaster coil at .035.
Runs good. You may have to play with heat ranges.
Old Jun 3, 2023 | 03:56 AM
You can get away with the stock gap of .030 - .040
Old Jun 3, 2023 | 04:14 AM
cutlassefi's Avatar
Hmmm not really. It’s the compression ratio, the fuel you’re igniting and the total amount of current available, from the coil AND the box, normally measured in millijoules.
Old Jun 3, 2023 | 05:39 AM
Olds Specialist LOL
thx for all the input, going with 35 where it was.
They were burning light brown at 35. i just thought they should have been at 45 with anything better then points.Atleast thats what was rule of thumb all these years.
Old Jun 3, 2023 | 05:57 AM
Spark plug gap is a function of the engine parameters and the coil voltage. People who weren't around when HEI first came out don't realize that GM went to much larger gaps on the factory HEI systems to comply with EPA requirements. Cars had to be able to meet emissions requirements after 50,000 miles without a tuneup (because owners really suck at basic maintenance). The large gap was selected to allow crud to build up on the plug electrodes without bridging the gap. The higher voltage was partly required to jump that larger gap. There's no real performance benefit to going larger than the gap needs to be.
Old Jun 3, 2023 | 09:00 AM
CANADIANOLDS's Avatar
You were probably fine where you were
friesjh
May 26, 2022 04:43 PM
olds 307 and 403
May 14, 2018 07:39 PM
DYSKIE
Apr 1, 2015 08:21 AM
rhaberm
Nov 15, 2010 11:17 AM
My442
Oct 12, 2009 04:36 PM
