Spacer?
Old Mar 27, 2017 | 05:57 PM
RandyW's Avatar
Spacer?
So I have had my 71 cutlass almost 2 weeks and have a curious question. I removed air cleaner today to check filter and install the pipe from snorkel to manifold. I noticed a spacer between breather and carb. Is it supposed to be there? Pipe will not reach even if I remove the spacer. What's up? Oh yeah, it's supposed to be a period correct 71-455
Old Mar 27, 2017 | 06:02 PM
Sometimes folks use a spacer to give clearance for an HEI distributor. If you can post pics of the carb/air cleaner/intake manifold/distributor it may help a lot with figuring out what's up.
Old Mar 27, 2017 | 08:10 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I am betting on it having an HEI. That is how I cleared the air cleaner on my 72 Cutlass.
Old Mar 28, 2017 | 07:36 AM
i am betting on it having an hei.
x2
Old Mar 28, 2017 | 07:54 AM
What carb is on it?
Old Mar 28, 2017 | 09:17 AM
mrolds69's Avatar
I don't know about the spacer between the carb and cleaner. If it has an aftermarket intake manifold like an Edelbrock the pipe won't reach the air cleaner. There were also many different hot air pipes used on different years, air cleaners and carbs.
defiant1
Sep 19, 2010 06:44 PM
tim72
Tech Editor's Desk
Apr 30, 2009 09:14 AM
deadmanscurve
Mar 12, 2009 06:42 PM
ziff396
Drivetrain/Differentials
Feb 13, 2009 04:56 PM
65Delta88
Mar 25, 2008 07:18 AM
