Source for .921 lifters
Old Sep 14, 2012 | 06:51 AM
Jay D's Avatar
Having the '67 400 ci engine rebuilt and the builder is having a problem finding .921 lifters, hydraulic flat tappet. His source is back-ordered and has been for about 3 months. All of my research has turned up "Not Available" even though the online site lists them as being carried by them.
Any help is appreciated.
Old Sep 14, 2012 | 07:42 AM
TripDeuces's Avatar
http://www.kanter.com///productdetai...Cat=32&Prc=378
Kanter has them
Old Sep 14, 2012 | 08:20 AM
Jay D's Avatar
Thanks, I will send it on to the builder.
Old Sep 14, 2012 | 08:24 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Both falconglobal and fastengineparts on eBay are selling them.
They are listed for Olds 394 engines, but they are the same VL59 lifters.
Old Sep 14, 2012 | 06:44 PM
wmachine's Avatar
Trying to remember member
Yes, they *should* be the same. The 394 lifters did not have the oil hole in the center where the pushrod seats, the 400s need the hole. So the 400 lifters can be used in the 394s, but not the other way around. Make sure you get ones the hole there.
Old Sep 14, 2012 | 06:54 PM
copper128's Avatar
Lt. Buzzkill (ret.)
I had an old NOS set of Sealed Power HT-957 lifters that came with a bunch of '62 394 parts I bought. They had the oil hole in the pushrod cup. I believe the .921" lifters for earlier Olds V8 engines which did not have the oil hole had a different part number.
Old Sep 14, 2012 | 07:11 PM
Oldsmaniac's Avatar
Egge machine has them
Old Sep 14, 2012 | 07:41 PM
Octania's Avatar
You may need a nostril stretcher though...
Old Sep 15, 2012 | 06:22 AM
Jay D's Avatar
I checked both Kanter and Egge. I'll probably go with the Kanter lifters as they are about $50 less. Thanks for all the replies.
Old Sep 16, 2012 | 11:50 AM
sammieolds's Avatar
Lifters
Jay I had the same problem 2 years ago Mondello makes them but the not running true I luck out and got a set on e-bay for 230.00 Good luck
bluecab
Sep 14, 2021 07:52 AM
Octania
Dec 2, 2013 10:01 AM
franks1967Olds442
Sep 9, 2012 08:03 PM
L69
Dec 2, 2011 10:27 PM
geckonz08
May 21, 2010 07:29 PM
