A Simple 455 EGR Question
Old Mar 11, 2023 | 04:53 PM
SirVelociraptor's Avatar
So I've been thinking of disabling the EGR system on '75 455 and from what I've gleamed from the FSM, it looks like if I remove the vacuum line running between the carb and the EGR valve, capping off the connection to prevent a vacuum leak, that would effectively keep the EGR valve from opening, effectively disabling the system. Is this correct or am I missing something?
Old Mar 11, 2023 | 05:56 PM
geardoc66's Avatar
You would be correct.
Old Mar 11, 2023 | 06:19 PM
Oldsguy's Avatar
Past Administrator
Capping off the connection at the carb baseplate...
Old Mar 12, 2023 | 06:48 AM
Yes that works, but the EGR only opens at part throttle cruise. It has no effect at other operating points. If the EGR system is working properly, there will be zero performance difference (however I'm sure the butt dyno will show at least a 2 second improvement in quarter mile times).
Old Mar 12, 2023 | 07:01 AM
Hammerdrop's Avatar
Just watch out for part throttle pinging.
Old Mar 12, 2023 | 12:30 PM
Oh I know it won't give me any real-world performance improvement, I'm just trying to clean up my engine bay some.
Plus it'd be nice if I could keep exhaust gases from depositing carbon and other crap in my intake.
Old Mar 12, 2023 | 12:41 PM
If all you're doing is capping the vacuum ports and leaving the EGR valve in place, that isn't "cleaning up" very much. Also, the carbon mainly comes from reversion, which is the exhaust pulse that goes into the intake when both intake and exhaust valves are open at the same time (the overlap part of your cam profile). Removing the EGR isn't going to change that much.
Camster
Oct 16, 2013 06:18 PM
Napoleon1991
Apr 26, 2013 03:07 PM
Rob delta
Dec 6, 2011 05:34 AM
henryk8398
Jun 14, 2010 10:42 AM
henryk8398
Mar 8, 2010 10:20 AM
