Rough running engine
455 with a fresh rebuild, it seemed to start and run fine during cam break-in. QFT carb was leaking from the secondary accelerator pump and I replaced diaphragm and reinstalled carb. Both primary and secondary pumps squirt well. Its running smoothly at idle but will barely run above idle. It starts to hesitate and buck. It doesn't stall out but no power and seems like it's missing badly. It will pull me down the street and back to house but barely. I assumed vacuum leak since I have been messing with all that on the engine install but I can't find one. That is what it is acting like though. It seems to run better when I advance timing but I have 18 degrees in and anymore and it's tough to start. Much less than 16 and it dies. MSD ignition is just a couple years old but I though maybe coil? Pulling spark plug wires one at a time seems to slow the engine so I don't find a miss.
I'm at a loss and appreciate anything you guys can suggest I test.
Thank you in advance.
I do have roller rockers, you think they need to be adjusted after absolutely up 40 mins of run time?
Last edited by exiledone; Jun 17, 2017 at 06:44 PM. Reason: Spelling. And further about rockers
sometimes it's best to start at the beginning, compression test, ignition components, battery voltage, wiring, grounds. A look at the throttle blades from underneath can tell you somethings wrong. Good luck
so I guess I have to assume this is running rich now. So I guess changing Jets is my only option?
The accelerator pump should move immediately with no delay period or it will hesitate.
How to adjust:
The first adjustment to check is the clearance between the pump operating lever and the pump diaphragm cover’s arm, at wide open throttle. This clearance should be around .015". The purpose for this clearance is to assure that the pump diaphragm is never stretched to its maximum limit at wide open throttle. This will cause premature pump failure. Once this clearance has been set take a good look at the pump linkage and work the throttle. Make sure that the accelerator pump arm is being activated the moment that the throttle begins to move. This will assure that pump response will be instantaneous to the movement of the throttle. These adjustments can be made by turning the accelerator pump adjusting screw that is located on the accelerator pump arm together with the pump override spring and lock nut.
How to adjust:
