Rocker Arm Adjustments
Old Jul 14, 2025 | 10:35 AM
Pigs Fly Garage's Avatar
5th Grade Dreaming
Howdy all,
I just finished installing my rebuilt 455.
Bored .30 over with Sealed Power Pistons.
Speedmaster Aluminum Heads
Cometic .27 head gasket
Elgin 1141 P cam 234/244 duration 520/542 lift
Correct length pushrods- can’t recall length
roller tip rockers 1.6 lift.
I degree’s the cam to 106- couldn’t get it to 107.
I adjusted the rocker arms using the simple method of zero lash, rotate 90, zero lash rotate 90, two full rotations. Then tightened preload by 3/4 turn.
After running the engine for a break-in period, my number 1 exhaust arm was knocking. After removing the valve cover I discovered the pushrod was out of adjustment, as in 1/4” lash. I have readjusted, but am wondering if this is possibly an indication of loosing a cam lobe? The engine runs well, but I am at a loss for why this valve was so far out of adjustment.
Any thoughts?
Old Jul 14, 2025 | 11:19 AM
heatmup's Avatar
If you use that method, assuming you have adjustable valve train, then you have to make FOUR full revolutions adjusting zero lash every 90 degrees.
Old Jul 14, 2025 | 01:04 PM
5th Grade Dreaming
Maybe that was an issue. I felt like 4 90s was one full rotation, the another 4 90s was a second full rotation. I guess I thought those 2 full 360 rotations would run through all the cylinders enough to take out lash at every valve before adding preload.
Old Jul 14, 2025 | 01:09 PM
heatmup's Avatar
You can always just use the exhaust open, intake close method.
Old Jul 14, 2025 | 01:14 PM
When in doubt, cut the filter open.
If there is something in the engine eating itself, that’s where you will find the debris.
Old Jul 14, 2025 | 01:21 PM
5th Grade Dreaming
Thanks, drained the oil. Oil looked great, ran a magnet through just to see if there were any particulates, and literally not one speck of metal. Smells a bit of gas, but I’m thinking that’s a timing issue to chase down? I also need to adjust the carb a touch?
Old Jul 15, 2025 | 05:55 AM
cutlassefi's Avatar
Fix that right away. Diluted oil will hasten cam wear.
Fix timing first, then make sure your throttle blades aren’t cracked open excessively to retain an idle. That’ll effect idle circuit operation.
Old Jul 15, 2025 | 12:34 PM
A magnet in the oil is not the same as cutting open the filter. There are lots of parts in an engine that can wear that aren’t magnetic.
Cut open the filter, then you can be reasonably sure the engine is t eating itself.
Old Jul 15, 2025 | 04:13 PM
5th Grade Dreaming
I’ll get after that filter! Appreciate the advice
Old Jul 15, 2025 | 04:25 PM
5th Grade Dreaming
Agreed. Planning to ensure my cam is degree’d properly. I’m pretty sure I nailed it on both the intake and exhaust degree. However, my brain is telling me I swapped the exhaust/intake numbers. Strange how the brain plays tricks once there is an issue. Pretty sure I got it right, but… The car idles great, throttle response is so much better than the old Delta 88 block. That rocker arm knock and loose pushrod just has my “worst case scenario” brain working overtime. I guess I also need to get at least one 45 degree plug wire for that #7 plug. The current boot has to be zip tied to the brake booster line to keep it from interfering with the steering.
Funny how upgraded parts always seem to require alterations. Kind of wish I just went with a standard cam, rocker arms, and valve covers.
Here’s to hoping by the extra HP will smoke away my regrets!
Fuelinmyveins
Jul 27, 2020 09:44 AM
GHOSTOWLGRID
Nov 25, 2017 03:12 PM
rcdynamic88
Oct 27, 2013 12:42 PM
Beob
Jul 18, 2011 07:24 AM
Gary Lagacy
Sep 20, 2008 01:35 AM
