Reputable engine builder/ installer in MS
Old Jan 17, 2017 | 02:18 PM
1972@442's Avatar
I have a 1972 cutlass supreme with a olds 350 engine and th350 transmission. The car is a head turner but I have wanted to swap the olds 350 out for a olds 455. A couple of shops said that I need to go with a chevy 454 due to the availability of parts. Do anyone know of a good engine shop near Biloxi, MS that can do the engine swap?
Old Jan 19, 2017 | 08:25 PM
wr1970's Avatar
You need to find a better shop.If you were closer i would help you do it. I am in Kansas.
Old Jan 19, 2017 | 08:33 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Stay away from the shops recommending the 454 Chevy. Nothing wrong with the 454 but they don't know anything about an Olds 455 and it is a much easier swap.
Old Jan 20, 2017 | 07:52 AM
Kennybill's Avatar
You need to do research. Whenever I have a project I try to plan out everything. Do you have a engine yet? Sounds like you're looking for a shop to take/drive your car to, then pickup when done.
Old Jan 21, 2017 | 06:58 PM
1972@442's Avatar
Yes I would like to find maybe a 455 crate engine, have it shipped directly to the shop if the shop can not order me one then just drop off the car and pick it up when done. I have found a couple of shops online that have 455 crate engines in stock for around $10k, that does seem a little pricey but I guess you get what you pay for just not trying to get ripped off too bad lol.
Old Jan 21, 2017 | 08:34 PM
74sprint's Avatar
$10K for a crate motor is nuts, unless your getting an all out Olds engine. Google for a Olds crate engine or go to places like J&S or Bill at BTR. Hell for that much money I could build an engine with a billet crank and more.
Ray
Old Jan 22, 2017 | 05:23 AM
cutlassefi's Avatar
Ray
I can guarantee you you'll pay at least 10K for a build from BTR if it's dynoed and makes any power at all.
And a billet crank will run you 2K alone. With that you'll have over 3K just in the rotating assembly. From there you can skimp if you want but that doesn't make sense if you're spending that much on a crank alone.
Last98
Aug 23, 2013 07:25 PM
Big Blue 72
Feb 18, 2013 01:49 PM
5998DownUnder
Ninety-Eight
Sep 22, 2012 04:11 AM
Gearhead442
Jan 21, 2012 04:52 PM
Gearhead442
Jan 20, 2012 05:24 PM
