Rebuildus interruptus
Old Oct 27, 2011 | 04:26 PM
zodiacblueS's Avatar
My first rebuild is almost complete, but I now have to let it sit for at least a month before I can get back to it. I'm a builder and started a project that needs to be done by Thanksgiving and will be b@lls to the wall for a while. My life keeps getting in the way of my fun. Anyway, I have the engine back together and in my Cutlass. Heads, manifolds, water pump (no coolant yet), no carb, no generator, no HEI. The new cam is well greased w/ lube as are the rockers and lifters, and the engine has been hand cranked one revolution to get #1 to T.D.C. Cylinders untouched since back from the machinist. Plugs are in. Crankcase is filled with Comp Cams break-in oil, and the oil pump has been primed, with oil flowing thru all the rods. Should I squirt some oil in the cylinders? The car is in a dry, semi-heated garage. Am I O.K. as is? Oil it? I'm so close I can taste it! ARRRRGGGHHH!
Old Oct 27, 2011 | 04:37 PM
Rickman48's Avatar
Be it 1/2 hour a day, I'd be out there working on it - that's too close!
Old Oct 27, 2011 | 05:26 PM
allyolds68's Avatar
Mine sat for three years before I even primed it, another 6 months before I started it. You'll be fine
Old Oct 27, 2011 | 05:38 PM
citcapp's Avatar
You should be fine. Wrap it in plastic and tie tight around the engine stand
Old Oct 28, 2011 | 12:52 PM
35mastr's Avatar
Already primed. No need to worry about it. Remove the lift plate and seal off the carb and dizzy points and it will be fine.
