Quadrajet Spacer?
Old Jan 7, 2018 | 04:00 PM
SteveRob442's Avatar
Quadrajet Spacer?
I am considering installing a 1inch spacer between the 7042251 Qudrajet and the W-30 aluminum intake. Are there any benefits noticed by any of you?
The motor is a 455 with roller cam, edelbrock heads, stainless 1 7/8 headers from American Racing
Thanks,
Steve R.
Old Jan 7, 2018 | 04:26 PM
Gary M's Avatar
Are you using the OAI hood and air cleaner?
If so, consider the clearance.
Can't comment on any HP gains. Good luck.
Old Jan 7, 2018 | 04:34 PM
QUADRAJET Spacer
the car does not have an OAL hood. Regulate air breather.
Old Jan 7, 2018 | 04:40 PM
shiftbyear's Avatar
Is it an open spacer or 4 hole? I have no experience except for reading. We can speculate all we want but putting the car on a chassis dyno or dragstrip and doing back to back testing is the only way to tell. I've read some peoples comments that they lost power across the board with a spacer. But testing is the only way to know with your combo. Good luck, please post results if possible.
Old Jan 7, 2018 | 05:02 PM
It is a W-30 alum. intake with the primary and secondary spread bore holes (four holes). I bought a spacer from Mr. Gasket and will try it for testing purposes. Will let you all know the results. The car should be back together in March/April.
Old Jan 7, 2018 | 06:25 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
IMO...Very minimal HP/TQ increase. Heat mitigation and better hot soak starts are the main benefits. You'll see even greater gains by blocking off the heat riser crossover in the intake or heads along with the isolator gasket. Benefits of blocking off the risers are zero hot start problems, greater hot weather throttle response and no burn marks on the expensive intake.
Old Jan 7, 2018 | 11:19 PM
Quadrajet Spacer
I bought the blocking plates for the heat risers from Inline Tube or from OPGI and definitely plan to do that. They are .060 thick. I have cometic intake gaskets. I am just wondering how do I incorporate the block plates into the intake gasket correctly/properly. I want to do it right the first time. Thanks.
Old Jan 8, 2018 | 06:35 AM
ELY442's Avatar
X2, I did the same thing. I lay down the plate over the cross over with a high temp silicone. Then, I lay the gasket over the plate. I use a hammer and lightly tap the gasket on top of the plate, this makes an imprint of the plate. Use a utility Knife and carve out the imprint.
Old Jan 8, 2018 | 08:22 AM
If you are not running an O.A.I. hood, get rid of the W-30 intake. That intake has exactly the same runners as the stock cast iron intake. The only difference is weight. You'll be much better off with an aftermarket intake instead of a spacer.
Old Jan 8, 2018 | 03:38 PM
cutlassefi's Avatar
if you are not running an o.a.i. Hood, get rid of the w-30 intake. That intake has exactly the same runners as the stock cast iron intake. The only difference is weight. You'll be much better off with an aftermarket intake instead of a spacer.
x2.
My2nd 69 442
Aug 11, 2017 07:36 PM
RickyHoliday
Feb 5, 2016 05:53 PM
auto_editor
Dec 20, 2010 11:24 PM
ziff396
Drivetrain/Differentials
Feb 13, 2009 04:56 PM
65Delta88
Mar 25, 2008 07:18 AM
