Push rod length
Old Sep 27, 2012 | 07:04 AM
LX89mustang's Avatar
Push rod length
What have some of you ended up with for pushrod length on a 455 build ? I have aluminum heads with roller rockers and we went through the process and came up with a rather long length . The length we came up with for proper geometry is 10.100 long . My friend thought that was a very long length .
Old Sep 27, 2012 | 07:22 AM
chadman's Avatar
The proper length is whatever gives you the shortest sweep across the valve tip. Mine are 9.95 if I remember correctly but that doesn't mean yours won't be different. Different lifters, cam base circle, rockers and cylinder head type can all skew what size is best for you.
Old Sep 27, 2012 | 07:27 AM
Well aware of the variance from setup to setup . Just want to make sure I am not way out in left field :-) .
bwheeler
Feb 24, 2015 07:15 PM
costpenn
Brakes/Hydraulic Systems
Dec 29, 2012 02:53 PM
ggriffin1960
Feb 5, 2012 07:20 PM
ggriffin1960
Jan 31, 2012 10:20 AM
defiant1
Apr 16, 2011 11:07 AM
