PUSH ROD for 425 Toronado
Old Apr 10, 2026 | 01:29 PM
Jelonek's Avatar
Jelonek
Hallo from Germany,
how long are PUSH ROD for my 1966 Toronado ? I ned only one , in the shop I have one with
243,7 mm - 9,59 "
239,3 mm - 9,42 "
and one "standard" ??? - " ???
what du you mean ? witch one ist for 1966 Toronado ?
Thanks Wojtek
Old Apr 10, 2026 | 06:11 PM
BillK's Avatar
According to the one catalog i have here it should be 9.594 so the firs one you listed.
Old Apr 11, 2026 | 04:16 AM
Jelonek's Avatar
Jelonek
so I have another catalog and I have a two possibility , the difference ist 4 mm !!!
thats a problem ...
Old Apr 11, 2026 | 07:06 AM
Run to Rund's Avatar
Toronado 425 cubic inch engines and 4-4-2 400 cubic inch engines had 0.921" diameter lifters which were also taller than the 0842" diameter lifters used in the 88 and 98 model 425 engines. Therefore the Toronado engine takes the 9-7/16" long pushrod while the 88 and 98 take the longer 9-5/8" pushrod.
Old Apr 11, 2026 | 07:30 AM
Jelonek's Avatar
Jelonek
I have lifter 0,921
so i need the short one of course completely set or would you change only two ?
Old Apr 11, 2026 | 07:34 AM
Inspect the ball ends for wear, roll the pushrods across a flat surface to check for straightness.
Old Apr 11, 2026 | 09:20 AM
BillK's Avatar
Originally Posted by Jelonek
I have lifter 0,921
So I guess you have the old pushrods ? what length are they ?
Old Apr 11, 2026 | 09:38 AM
Jelonek's Avatar
Jelonek
Yes, that would be my plan, but the car is 100 km away, so I can't do it until Monday because the garage is locked now. But as I said, I also want to measure the length so I don't make a mistake.
By the way, do you know of any companies that sell individual only 1 or 5?
Old Apr 11, 2026 | 10:20 AM
BillK's Avatar
You should be able to order a single one from almost anyone.
Old Apr 11, 2026 | 02:04 PM
Jelonek's Avatar
Jelonek
Ok thanks
what about the ⛽️ price in USA ??
in Europe is now really high and everything from day to day higher
Old Apr 11, 2026 | 06:41 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
$4-5/gallon. Diesel is higher. Stupid. Dont care. Everything I own gets 10-20mi/gallon. Have to have a V8!
Old Apr 11, 2026 | 07:46 PM
Meh. My DD has a 2.5 liter engine producing 120 horsepower per liter and a 6 speed manual transmission. Absolutely a blast to drive, so don’t worry about gas mileage.
Old Apr 11, 2026 | 11:28 PM
Jelonek's Avatar
Jelonek
This is really not expensive
in Germany one gallon costs 9,5 $
Old May 14, 2026 | 07:06 AM
Jelonek's Avatar
Jelonek
Hello everybody
So the engine is rebuilt, I have a very good engine, perfect running and only two problems
The one of them is vacuum system and lights and the second one is air valves and kickdown power. I opened another threat about that
For everybody for the help once more time, thank you very much
Best greeting from Germany
Wojtek
Jelonek
May 25, 2025 01:55 PM
shiftbyear
Nov 28, 2021 12:39 PM
smietana
Dec 28, 2018 08:48 AM
lostinspacetv
Jun 12, 2017 07:11 AM
ZASX
Aug 13, 2008 09:06 PM
