Pulley question
Pulley question
My 68 Lemans when I bought it had a 67 olds 425 from a Toro installed from the previous owner. I had no power steering or A/C. The motor had a dead cylinder on number seven.
I picked up a low mileage 455 from a 69 delta 88, freshed it up, and it runs great. I'm still using the pulleys from the 425 now a JE water pump pulley and a JA crank pulley.
I've since picked up a power steering setup (box, pump, and brackets etc.) from a 68 442, and it has the KG single groove pulley. I'm running the short water pump.
So the question is, can anybody with an assembly manual etc. tell me what code crank and water pump pulleys I need to work with the 68 pulley of the power steering pump?
Thanks in advance guys. If I've left anything info wise out, let me know.
Crank
KB 399402
2g [* Note 1]
6.4 x 2.2"
WP
KE 399401
2g
7.10 x 2.0"
Belts: Aft groove: C-WP-Gen belt #399596;
2nd groove: C-WP-PS belt #399594;
Source:
68 Asm. Man.
6-1, 111
wildaboutcars.com - join if you have not yet, free access to the AM.
KB 399402
2g [* Note 1]
6.4 x 2.2"
WP
KE 399401
2g
7.10 x 2.0"
Source:
68 Asm. Man.
6-1, 111
WOW, thanks man, that will make my hunt easier.
