pulley lineup
Old Jul 21, 2012 | 08:55 AM
tommy23t's Avatar
pulley lineup
Hi all,
Finally moving again on the 71 'vert 442 clone (rec'd fully disassembled, lots of boxes). I finished the engine, had no waterpump originally, so I installed one. I went to install the pulleys, they seem to be a pulley width off. This is a 455, no a/c. Any help is appreciated, along with some pics of the bracket setup for the alt and p/s. I have the assy manual, but seem to be missing some special studded bolts and spacers. I also don't know if the bypass hose is correct (straight 3/4 hose). When the thermostat housing is bolted on, the lineup is off as well (not bolted in this pic).
thanks for you help.
tommy23t
Old Jul 21, 2012 | 09:30 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Looks like you have the wrong water pump. The one on your engine looks like a 5.6" snout length for 68-70 cars with AC. You need the 5.1" snout. There is also a 6.1" snout that came later on the 1973-90 cars.
Remove your wp pulley, and put a straight edge against the flange. Then measure from the face of the timing cover to the bottom of the straight edge and post your results.
Old Jul 21, 2012 | 10:17 AM
tommy23t's Avatar
You are right on. Measures approx 5.6" Looks like I need a water pump.
Old Jul 21, 2012 | 12:08 PM
Rickman48's Avatar
And don't forget to clamp the hose - major water leak!
Old Jul 22, 2012 | 08:53 AM
Octania's Avatar
That is OK bypass hose alignment
Most pre-71 non-AC apps will use the 5.1" WP
47 Convertible
Site Suggestions
Mar 29, 2013 05:19 PM
drpruitt
Sep 25, 2006 06:46 AM
DonFrost
Jun 25, 2006 03:14 PM
<Rocket Power>
Dec 8, 2004 05:44 AM
