Proper hose location
Old Feb 12, 2010 | 01:50 PM
1971 442 convert's Avatar
1971 442 convert
Can any one tell me if the back red hose is in its proper position?
Does it really curl up like that?
Old Feb 12, 2010 | 07:55 PM
70Post's Avatar
The factory heater hose for that spot is a preformed/molded hose. You just have a piece of straight hose on there.
You can get repro versions of the correct formed/molded hoses from any of the repro parts places like Supercars Unlimited (Oregon), Fusick, Parts Place, Year One.
Here's a link to Supercars's listings for them:
http://www.supercarsunlimited.com/It...CategoryID=206
Looks good under that hood!! Nice work.
Also...you have the alum spacer on your water pump....is your fan one of the 4 blade/non fan clutch versions??? Don't see that very often.
There's also a black foam "insulator" used on your longer heater hose that runs up to the water pump. It slips over that hose and it's placed over the spot where the hose runs on top of your alternator bracket...sort of an "anti-rub" insulator. Fusick and the other repro parts vendors all sell this "insulator" in case you were looking for one.
Old Feb 13, 2010 | 08:42 AM
1971 442 convert
Thanks 70Post.
Yes it is a 4 blade and yes they have made a big improvement under the hood. Sounds like you have a lot of knowledge. I appreciate your input.
Sampson
Mar 24, 2015 09:33 AM
defiant1
Brakes/Hydraulic Systems
Mar 12, 2015 01:15 PM
tinner
Aug 24, 2012 12:41 PM
hvysupreme
Aug 14, 2012 11:01 AM
Sixoh
Mar 7, 2007 06:18 AM
