Pro Comp Air Gap Intake Torque
Old Jul 10, 2012 | 06:37 PM
Delmont 88 PA's Avatar
Does anyone know the tightening specs for a Pro Comp Air Gap intake on a 455?
Old Jul 10, 2012 | 06:44 PM
Should be 30#'s and work form the inside out.
Old Jul 11, 2012 | 04:27 AM
cutlassefi's Avatar
I'd go with 25, the same that edelbrock recommends.
Old Jul 11, 2012 | 06:08 AM
TripDeuces's Avatar
http://www.edelbrock.com/automotive_.../2000/2151.pdf
Oldsmobiles get torqued from the outside in and to 25 lb/ft
Old Jul 11, 2012 | 06:19 AM
Hmmmm-I've always tightened all intakes from the inside out, go figure!
Old Jul 11, 2012 | 06:51 AM
380 Racer's Avatar
With aftermarket intakes, I have done it both ways.......no difference both ways sealed.
Old Jul 11, 2012 | 06:17 PM
Thanks! Another question for anyone who has one of these intakes. There are only 4 bolt holes on each side. It appears that 2 on each side are not drilled. Is this correct?
Thanks,
Chris
Old Jul 18, 2012 | 06:39 PM
SBORule's Avatar
It's made in China, it must be better that way.
Old Jul 18, 2012 | 07:01 PM
cutlassefi's Avatar
Thanks,
Chris
Yes the new Victors from Edelbrock are drilled the same way.
Old Jul 19, 2012 | 04:43 PM
Thanks and it does appear that the holes are bored from the bottom up--probably with a long drill bit from China. :')
olds330
Nov 29, 2014 06:40 AM
rcdynamic88
Oct 20, 2014 11:28 AM
70F85
Sep 22, 2013 08:22 AM
Delmont 88 PA
Oct 30, 2012 06:08 PM
firefrost gold
Dec 19, 2011 01:00 PM
