Porting Heads for Street/Strip Use
Old Nov 6, 2010 | 09:45 AM
Oldsproject's Avatar
65 post sport coupe w/425
Been awhile but started my second project (65 442). Frame and suspension are done, block is getting bored this week and I'm starting the head work. Don't want to over do it on the heads (A heads - no bumps) so looking at the following for some incremental performance:
Open up (gasket match) and polish the exhaust runners and bowl. Basically opened up the port to match the gasket then blended everything back to the bowl, cleaned up the bowl and teardropped the valve guide.
Open up the intake ports and runners but leaving the bowl alone. Haven't started this yet but was thinking I'd open up the ports similarly, blend the runners back to the bowl, not polishing the runners, leaving the bowl alone but teardropping the guide?
Leave Chambers alone.
Will run stock exhaust and intake manifold. Realize I won't get much in terms of performance and read something about leaving the intake bowls alone on street cars to get better drivability/atomization of gas at city speeds. Since I'll be running stock exhaust not planning to braze the crossover or fill risers. Sound about right?
Old Nov 8, 2010 | 07:57 PM
Warhead's Avatar
I would do it differently.
I would clean up the bowls first, and the guide bosses.
No matter what, you want to make all of the ports equal. Don't start on one, then give up, that makes your parts junk. Do all the bowls at the same time, and make them equal, then do all the guide bosses at once (equally), then see if you are up to anything else.
Forget the port matching, no real benefit, but if you go too big, a big loss in power.
Also, I would fill the heat risers and use an electric choke, even if you use the stock manifolds. Inexpensive HP here.
My Opinions.
Jim
Old Nov 8, 2010 | 09:16 PM
My Opinions.
Jim
Thanks Warhead, basically got the exhaust runners, ports, bowls and guide bosses done. Assuming the loss of power your describing is primarily when you start messing with the intake side? But maybe not.
Read somewhere that cleaning up the intake side too much will cause the gas to puddle affecting street drivability? Was not going to do much on the intake side except remove any obvious flashing, square up the ports a bit and teardrop the valve guides. Make any sense or on the wrong path?
Old Nov 9, 2010 | 06:45 AM
cutlassefi's Avatar
My Opinions.
Jim
X2 and don't overlook a well done 4 or 5 angle valve job with backcut valves. That's worth a few extra hp as well.
Old Nov 10, 2010 | 06:00 AM
Warhead's Avatar
X2 on the backcuts, and multi angle valve job.
Do not forget to new guides, and Viton seals.
And I meant intake side, if the manifold ends up bigger than the port.
I would not worry about gas "puddling" in a 1 inch section of a 12 inch port, where everything is moving 50ft/sec<, unless the cam is flat.
Just me
Jim
Old May 24, 2011 | 12:18 PM
nonhog's Avatar
Registered car nut
Got pictures?
Been thinking the same thoughts on my yet to be done "C" heads.
Can't afford porting but I could do some clean up.
Warhead had mentioned inexpensive HP by filling the crossover.
Any builders know how much HP is gained? (I know it'll be a ballpark)
Old May 24, 2011 | 04:26 PM
Originally Posted by nonhog
Got pictures?
Here's a couple:
Old May 24, 2011 | 09:41 PM
64Rocket's Avatar
Your most important work is in the bowl area and the roof. I would not have touch the floors. Bowl work and guides tear drop is the place to work. Fill the heat cross over. Weld up the center exhaust divider and mill flat. They look like "A" heads. Just replace the studs with 3/8 bottom 3/8 tops and roller tip or roller rockers.
Gene
Old May 26, 2011 | 09:42 AM
67 Cutlass Freak's Avatar
Head Work
I agree that the most significant gains will come from bowl work and larger back cut valves. Port matching on the intake side will not help very much unless the entire port is opened up. Filling the heat riser and welding up the exhaust divider is well worth the effort IMHO. The short side radius is also a good place to spend time. Here's some photos of some of the port work I've done.
Old May 26, 2011 | 11:23 AM
455man's Avatar
He mentioned stock exhaust manifolds so would welding up the exhaust divider help?
Old May 26, 2011 | 01:04 PM
455man- He mentioned stock exhaust manifolds so would welding up the exhaust divider help?
Good point. I'm sorry I must have missed that. Welding up the dividers is pointless when using stock exhaust manifolds. The stock manifolds are wide open between the center two ports. The whole point of welding the dividers is to prevent exhaust gasses from mixing between the center two cylinders and to actually allow for tuned headers to function as designed.
Old May 26, 2011 | 02:35 PM
64Rocket's Avatar
If he uses the "W / Z" manifolds or the Thornton reproductions the the center divider weld would be well worth it.
Gene
Old Jun 4, 2011 | 06:47 PM
SBORule's Avatar
Cutlass Freak
Why are you showing a small block head as a before picture of the big block heads you cleaned up the intake ports on?
None of you guys have tear dropped the valve guide bosses, narrowed yes, tear dropped no.
If you want to see how to tear drop valve guides, check out this page.
http://www.angelfire.com/sports/hotrodder/
Also, you see the ridge that goes around the valve seat? You should bring that down flat with the valve seats, that'll kill your low lift flow numbers and the valves are open more @ low to mid lift than they are at full lift.
Filling your heat crossovers with aluminum is only worth a couple horsepower but when comes loose and starts rattling around in your heads making the same sound as if you spun a rod bearing, then it isn't worth crap. I had my crossovers filled by the professionals @ M&J Proformance who assured me that wouldn't happen, it did.
Smitty275
Jun 23, 2014 06:23 PM
Daverd
Jan 15, 2014 06:20 AM
Shanghai Smith
Jul 22, 2013 10:05 AM
DAN76
Nov 16, 2010 02:39 PM
johnfharding
Dec 16, 2008 07:20 AM
